Thanks for your reply Easy peasy
If the wiring is flakey, could that cause this problem many times?
Thanks for your reply AdamsN
This happens in an open circuit situation without any load. The circuit works well, the problem happens when I touched it.
Thanks c_mitra for your reply
OK I will try that. But the problem is that the circuit works well at first before I have touched it.
Note: I switched it OFF and ON many times without any problem and I let it run for about 20 minutes in every time. So, what would have happened to the IC by touching it??
Thanks for your reply Tony
OK I will try that, but it works well before I have touched it, and I have also seen many posts in many forums that present a working circuit without doing this bypassing. So, what could be my problem??
