vilela
Newbie level 5
- Joined
- Apr 11, 2013
- Messages
- 10
- Helped
- 6
- Reputation
- 12
- Reaction score
- 6
- Trophy points
- 1,283
- Location
- Brazil
- Activity points
- 1,366
IR2110 getting demaged in full bridge inverter with MOSFET and Arduino
Hi everyone!
I've been in the forum for a while, reading and analysing the posts much more than posting, trying to find threads were the solved problems are similar to mine... In many situations I've found answers to my questions, but this time it didn't happened, so I'm opening this thread to ask for help.
I'm building a full H bridge inverter controled by an Arduino board. The circuit diagram follows.
Well, each half H bridge works fine, in a isolated manner. I mean, one half bridge works nice if the other is disabled, and vice-versa.
However, if I put both to work toghether, one of the IR2110 gets damaged (a least i think it gets) in the following manner: the LO pin (pin 1) will not low again. As LO it is always high, we fatally get a crossfire when HO turns high.
Taking a closer look in the IR2110 outside the breadborad, we have found that pins 3 and 1 (VCC and LO) are short circuited. It feels like the internal mosfet between VCC and LO is short circuited (please see the following IR2110 diagram, taken from the datasheet).
My doubts:
- Are the diodes fast enough (1N4007)?
- Since we are testing the topology, the contro signal is a square wave (properly built to avoid crossfire), but also very slow: Ton of 100 ms and Toff of 10 ms. So, the bootstrap capacitors are big, like 2200 µF. Could it be a problem (I don't think so, but...)?
Well, all suggestions are welcome, we already have 4 useless IR2110... :smile:
Please note that Q5 to Q8 are working simply as inverters (6N137 has inverted output logic).
Thanks in advance!
Regards,
V.
Hi everyone!
My doubts:
Thanks in advance!
Regards,
V.
