IR transmitting and Receiving Using pic12f675
nick703
Advanced Member level 1
surat
hello friends ,
i have read this thread to operate relay using Remote .
file:///H:/Proteus%20Project/NEC%20IR%20REMOTE%20ALL/NEC%20IR%20REMOTE%20receiver/Microcontroller%20Projects%20%20IR%28infrared%29%20Remote%20Control%20Relay%20Board%20with%20PIC%2012F675%20Microcontroller.htm
Transmitter code is
// Global includes
#include <htc.h>
__CONFIG(FOSC_INTRCIO & WDTE_OFF & PWRTE_OFF & MCLRE_OFF & CP_OFF & CPD_OFF);
#define LED 	GPIObits.GPIO5		// IR port status indicator LED defination
#define RELAY1 	GPIObits.GPIO0		// RELAYS PORT definations
#define RELAY2 	GPIObits.GPIO1
#define RELAY3 	GPIObits.GPIO2
#define RELAY4 	GPIObits.GPIO4
#define IRSENSOR GPIObits.GPIO3		// IR PORT defination
//#define TICKSPERMS  1004      // tick in a milli second
#define TICKS11ms 	11044      	// ticks in 11ms
#define TICKS5o5ms 	5522 		// ticks in 5.5ms
#define TICKS2o3ms 	2309 		// ticks in 2.3ms
#define TICKS3ms  	3012		// ticks in 3sm
#define TICKS0o2ms	200			// ticks in 0.2ms
#define TICKS8ms 	8032		// Tick
unsigned int TIMEOUT  =   TICKS11ms;       	// the pulse should occur before this time excede Otherwise it is an error
unsigned int PREPULSE = TICKS8ms;			// the interrupt should occur after this time Otherwise it is an error
static unsigned short long timer;			// varible to keep track of long timeouts  ( it can also be int if you want to save flash memory for some other purpose  )
static unsigned char dataready;				// varible to use as flag when data is completly received and  ready it is 1 else 0
static  unsigned char necpoj=0; 	 				/* (necpoj=NEC position )this varible is used to keep track of the edges of the input singal
											as decoding of the singal is done by a state machine
											so this varible acutalley sotores what state we currently are
							 				and total bits 32 and 2 leading pulse */
static unsigned char address=0,notaddress=0;	// these varible are used to store received address
static unsigned char command=0,notcommand=0;	// these varible are used to store received address
void interruptOnChangeIsr(void);  				// interrupt service routine for interrupt on change of input port for IR sensor of mcu
void timerInterruptIsr(void);					// interrupt service rouine for timer0
void interrupt t0intr(void)
	if(INTCONbits.T0IF)							// check the timer0 over flow interrupt flag
	timerInterruptIsr();						// timer0 overflow interrupt has been occur call the isr
	INTCONbits.T0IF =0;							// clear the timer0 interrupt flag
	else if (INTCONbits.GPIF)					// check the interrupt on change flag
		LED=1;									// to blink the LED when IR signal is received
		interruptOnChangeIsr();					// interrupt on change has been detected call the isr
		INTCONbits.GPIF =0;						// clear the interrupt on chage flag
		LED=0;									// to blink the LED when IR signal is received
/* THE main source code Start here*/
void main()
    CMCON=0x7;				// disable the comparator
    ANSEL=0x00;				// all pin are Digital
    TRISIO=0x8;   			// Only GP2 is set to input rest are out
	TMR0 = 0;				// clar the timer
	OPTION_REG = 0x88;		//pullups are disabled
							//timer0 clock source is internal
							//timer0 perscaller is 1:1 (disabled "assigned to WDT")
	IOC = 0x8;   			//interrupt on change is only to the GPIO3
	INTCONbits.T0IE = 1;	// Timer0 overflow interrupt enable
	INTCONbits.T0IF = 0;    // clar the timer0 intrrupt flags
	INTCONbits.GPIE = 1;	// external interrupt on GPIO3 pin(4) is enabled
	INTCONbits.GPIF = 0;	// clear the external interrrupt flag
	INTCONbits.PEIE = 1;    // peripheral intrrupt enable
	INTCONbits.GIE = 1;     // GLOBL interrupt enable
	EEADR = 0x00;			// load the state of port from EEPROM
	EECON1bits.RD = 1;		// Start reding EEPORM
	GPIO = EEDATA; 			// LOAD The readed data form EEPORM to GPIO
	while(1)      			// wait forever for  the data received and ready
	if(dataready)			// data is received and ready to be procssed
		// key1  0x50	to	Toggle relay 1	// these are command of the IR remote control which i have
		// key2  0xD8	to	Toggle relay 2
		// key3  0xF8	to	Toggle relay 3
		// key4  0x30	to	Toggle relay 4
		// key5  0xB0	to	Turn off all the relays
		switch(command)	// swich on
		case 0x50: RELAY1 = !RELAY1;		//Toggle relay 1
				   break;
		case 0xD8: RELAY2 = !RELAY2;		//Toggle relay 2
				   break;
		case 0xF8: RELAY3 = !RELAY3;		//Toggle relay 3
				   break;
		case 0x30: RELAY4 = !RELAY4;		//Toggle relay 4
				   break;
		case 0xB0: RELAY1 = 0;				//Turn off all the relay
				   RELAY2 = 0;
				   RELAY3 = 0;
				   RELAY4 = 0;
				   break;
		default :
					break;
		EEADR = 0x00; 			//Write PORT status to EEPROM
		EEDATA = GPIO;			// load the current status of GPIO to EEPROM write register
		EECON1bits.WREN = 1;  	// Enable EEPROM write
		INTCONbits.GIE = 0;		//1	disable the interrupts as it may currupt the EEPROM data
		EECON2 = 0x55;			//2
		EECON2 = 0xAA;			//3	(1,2,3) require sequence
		EECON1bits.WR = 1;  	// satart writing
		INTCONbits.GIE = 1;  	// Enable the interrupts
		dataready=0;			// data has been processed so clear the dataready flag
unsigned short long tdiff;
unsigned char pin;
static unsigned long rxbuffer;
tdiff = ((timer<<8)+TMR0) ;     // calculate how much time has been passed since last interrupt
								// the time shold be less then time out and greater than PREPULSE
pin = IRSENSOR;					// store the current status of Sensor
TMR0 = 0;						// reset the timer0 to measure the next edge(interrupt) of input
timer = 0;						// reset the timer varible to
/* state machine is started here and it totally managed and keeps track of its states using the varible necpoj
here are the details of necpoj ( NEC position ) varible
if
necpoj == 1       we just detected the first edge of the input singal it may also mean(if interrupt is not false) that the 9ms leading pulse started
				  after the first edge THE next pulse is expected to arrive around 9ms so the TIMEOUT is set to 11ms and PREPULSE is set to 8ms
necpoj == 2 	  we just detected the second edge of the input signal and we finished the 9ms leding pulse and now 4.5ms space started
				  after the second edge the next pulse is expected to arrive around 4.5ms so TIMEOUT is set to 5.5ms and PREPULSE is 3ms
necpoj == 3  	  we just detected the third edge of the input singal and we finished 4.5ms space and addres lsb is now started
				  after the third edge the next pulse is expected to arrive around 562.5us so TIMEOUT is set to 2.3ms and PREPULSE is 0.2ms (timeout can be much less at this state but to do this i have to add one more if else statemetnt)
necpoj == 4 	  we just decected the forth edge and the 562.5 us burt of LSB of address has ended now a little space for '0'562.5us  or for '1' 1.6875ms
				  after the forth edge the next pulse is expected to arrive for '0' around 562.5us  and for '1' 1.675ms so TIMEOUT is set to 2.3ms and PREPULSE is 0.2ms
necpoj ==5 to 66  data pulse keep comming
					TIMOUT and PREPLUSE remain same as above.
necpoj ==67		  we just fined the command inverse MSB space not the final 562.5us burst has stated  so we fined the receiveing
				  now we will check the address and command for being correct
if ((tdiff>PREPULSE) && (tdiff<TIMEOUT) )		// the edge (interrupt) occurrence time should be less then the TIMOUT and greater then PREPULESE else it is an fake singal
{												// At the very first edge (necpoj==0)  this conditon will always false and the false block of this if will bring the state machine (necpoj) to position 1(position 1 means 9ms leading pulse has started now we have to wait for 4.5ms start pulse to occur)
	if(necpoj==1 || necpoj==2)					// when we are hear it means 9ms leding pulse has ended and now we are necpoj=1 or necpoj=2
			if((pin==1) && (necpoj==1))
			necpoj++;
			TIMEOUT 	= TICKS5o5ms;  			// timeout for 3rd pulse 5.5ms
			PREPULSE   	= TICKS3ms;				// PREPULSE for 3rd pulse 3ms
			else if((pin==0)&& (necpoj ==2))
			necpoj++;
			TIMEOUT 	= TICKS2o3ms;  			// now data starts so timeout is 2.3ms
			PREPULSE   	= TICKS0o2ms;
			else								// this block handle the conditon if any error occur after the completing the pre pulses
			necpoj = 0;							//reset the state machine
	else if(necpoj>2)							//now we are picking the data
			necpoj++;					 		//necpoj sill inrement on every edge
				if(necpoj&0x01)					// here we check the if necpoj is an odd number because when necpoj goes greater then 3 then
									    		//necpoj will always be and odd value when a single bit tranmission is over
					rxbuffer=rxbuffer<<1;		//shift the buffer
					if(tdiff>1250)				//we are here means we just recevied the edge of finished tranmission of a bit
												// so if last edge was more than 1.24 ms then the bit which is just over is one else it is zero
					rxbuffer = rxbuffer | 0x1;
				//	GPIObits.GPIO5 = !GPIObits.GPIO5;
					else
					rxbuffer = rxbuffer |0x0;
			    //	GPIObits.GPIO4 = !GPIObits.GPIO4;
			if(necpoj >66)						// we have reached (Leading pulse 2 +address 16+~address16+ command 16+ ~command 16+ last final burst first edge 1)=67th edge of the message frame means the date tranmission is now over
			address 	= (rxbuffer>>24)& 0xFF;			//extract the data from the buffer
			notaddress 	= (rxbuffer>>16)& 0xFF;
			command 	= (rxbuffer>>8)	& 0xFF;
			notcommand 	= (rxbuffer)	& 0xFF;
			rxbuffer=0;									//clear the buffer
					if((!(address & notaddress)) && (!(command & notcommand)))		// check weather the received data is vaild or not
					dataready =1;
					else
					dataready=0;
			TIMEOUT 	=  	TICKS11ms;					// weather we received the vaild data or not we have to reset the state machine
			necpoj=0;
	else
	TIMEOUT 	=	TICKS11ms;							// some error occured reset state machine
else
	if(pin==0)				//we are here means that after a longtimeout or PREPULSE we just detect a pulse which may be the start of 9ms pulse
	necpoj = 1;				// yes it could be the start of 9ms pulse
	else
	necpoj = 0;				// no it's not start of 9ms pulse
	address 	= 0xFF;
	notaddress 	= 0xFF;
	command 	= 0xFF;
	notcommand 	= 0xFF;
	dataready 	= 0x000;
	TIMEOUT =  TICKS11ms;		//default timing
if(timer<0xFFFF)			// this code is to increment the variable timer's value on every over flow but this if conditon will prevent this variable form rollover when a long timeout occurs
timer++;
and Receiver code is
// Global includes
#include <htc.h>
void main()
				   break;
				   break;
				   break;
				   break;
				   RELAY2 = 0;
				   RELAY3 = 0;
				   RELAY4 = 0;
				   break;
		default :
					break;
		EECON2 = 0x55;			//2
unsigned char pin;
if
			necpoj++;
			necpoj++;
					else
					dataready =1;
					else
					dataready=0;
			necpoj=0;
	else
else
	else
	address 	= 0xFF;
	notaddress 	= 0xFF;
	command 	= 0xFF;
	notcommand 	= 0xFF;
	dataready 	= 0x000;
timer++;
and my proteus file is
View attachment SIMULATION.rar
but simulation not work please help me!!!!
ok sorry for some change on my circuit design please have look below simulation file . but relay is not trigger ?
  • test.rar
In case someone is motivated to check the simulation design, he'll need the hex files. Or even better the *.cof files together with the sources to perform source level debugging in Proteus.
To take advantage from the simulator, you should think about a systematic test strategy. You already connected an oscilloscope at RX and TX of the IRLINK component, what do you think about the observed signals? Are they as expectable? Is it more likely a transmitter or receiver problem?
test1.JPGok now below is the simulation file and remote and receiver hex file
  • receiver hex.rar
  • remote hex.rar
The TX signal looks inplausible (14kHz rather than 40 kHz), the IRLINK behavioral model is apparently just a one shot, so it produces a pulse train instead of a receive pulse per burst.
You didn't post the transmitter code, we can't see where it's wrong.
hey fvm
i post my transmitter and receiver code in post #1 .
actually i completely transmit and receiving i see in proteus oscilloscope but my relay is not turned on . please help me any thing is wrong in my code?
And by the way my
Transmitting code is 12f615
receiving code is 12f675
here is oscilloscope view what i get .
The title claims so. But you posted two identical copies of the receiver code...
You need to switch to a faster time base to see why the signals are wrong. (As described in my previous post).
Please come back with new facts.
hey sorry FVM now below is my transmitting code and receiving code.
Transmitter
#include <htc.h>
__CONFIG(FOSC_INTOSCIO & WDTE_OFF & PWRTE_OFF & MCLRE_OFF & CP_OFF & IOSCFS_8MHZ & BOREN_NSLEEP);
#define _XTAL_FREQ 8000000			// required for delay Routines.
#define IR_LED 	GPIObits.GPIO2		//IR LED is conntected to this port
#define KEY_1	GPIObits.GPIO0		//Switces pin definition
#define KEY_2	GPIObits.GPIO1
#define KEY_3	GPIObits.GPIO3
#define KEY_4	GPIObits.GPIO4
#define KEY_5	GPIObits.GPIO5
#define ADDRESS 0x01				//NEC protocol address for the Data Frame (MSB first)
									//if you are planning to use this with http://www.circuitvalley.com/2012/09/infrared-ir-nec-microcontroller-pic-avr.html IR realy borad then this field can be any thing because the Receiver does't look for this.
									//if you are planning to use the remote with some other target then please put the address here is MSB first order
									//you can have different address for different keys. please modify the GPIO interrrupt on change routine.
#define DATA_KEY_1	0xF8			//Data For KEY_1 (MSB first)
#define DATA_KEY_2	0x50			//Data For KEY_2 (MSB first)
#define DATA_KEY_3	0xD8			//Data For KEY_3 (MSB first)
#define DATA_KEY_4	0xB0			//Data For KEY_4 (MSB first)
#define DATA_KEY_5	0x30			//Data For KEY_5 (MSB first)
void sendFrame(unsigned char , unsigned char );		//sendFrame(address,data) sends the whole IR frame
void sendByte(unsigned char );						//sendByte(byte) this function is used by the sendFrame to send 4 indivisual btyes
													//SHOULD NOT BE CALL FROM ANY WERE ELSE except the sendFrame Function.
void sendRepeate();									//Sends the Repeate Code after Message Frame.
void interrupt swInt(void)
		__delay_ms(2);						//check for key debounce
		if(!KEY_1)							//check if the Key_1 is pressed (gpio is low)
			sendFrame(ADDRESS,DATA_KEY_1);	//send the frame
	 		while(!KEY_1)					//if the key is still pressed
			sendRepeate();					//send Repeate codes.
		}else if(!KEY_2)					//check if the Key_2 is pressed
			sendFrame(ADDRESS,DATA_KEY_2);	//send the frame
			while(!KEY_2)					//if the key is still pressed
		}else if(!KEY_3)					//check if the Key_3 is pressed
			sendFrame(ADDRESS,DATA_KEY_3);	//send the frame
			while(!KEY_3)					//if the key is still pressed
		}else if(!KEY_4)					//check if the Key_4 is pressed
			sendFrame(ADDRESS,DATA_KEY_4);	//send the frame
			while(!KEY_4)					//if the key is still pressed
		}else if(!KEY_5)					//check if the Key_5 is pressed
			sendFrame(ADDRESS,DATA_KEY_5);	//send the frame
			while(!KEY_5)					//if the key is still pressed
		KEY_1;								//this is requited to end the mismatch condition
void main()
	CMCON0bits.CMON	=0;		// disable the comparator
    ANSEL		= 0x00;		// all pin are Digital
    TRISIO		= 0x3B; 	// Only GP2 is set to output rest are input
	OPTION_REG 	= 0x5F;		//pullups are enabled
	WPU 	= 0x3B;			//week pullups are enabled for all switches.
	GPIO 	= 0x3B;			//put hight to the latch value of each gpio
	T2CON 	= 0x04;			// prescaler 1:1 (Timer2 is required BY the ECCP module to generate 38Khz Frequency)
							// Timer2 is on
							// postscaller 1:1
	CCPR1L			= 0x1A;	//CCP module comprison resistor to set 50% duty for 38KHz signal
	PR2 			= 51;	//CCP module period register to generate 38Khz signal
	CCP1CON 		= 0x20;	//set Two LSB of PWM Duty 8MSB are in CCPR1L the module will turned on later
	IOC 			= 0x3B; //interrupt on change is assigne to all the port pin.
	while(1)
		SLEEP();			//put the MCU into Sleep mode forever , will wake-up when ever any key press is detected.
							// the measured current consumption in this mode is ~ 29na ( much lower then the datasheet claim 50na)
void sendFrame(unsigned char address, unsigned char command) // this routine send the whole frame including 9ms leading pulse 4.5ms space address ~address command ~command end of message bit.
	TMR2 = 0x00;					//clear the TMR2 register before we start generating 38Khz Signal on the GPIO
	CCP1CONbits.CCP1M = 0xC;		//put The CCP module into PWM mode , the Duty is 50% and freqeucny is 38Khz as allredy set,
	__delay_us(8999);				//wait for ~9ms this rountine will delay for 8.999 ms + (3*500ns) = ~9ms (500ns is the instruction execution time at 8Mhz) and next instruciton will take 3 ins cycle to execute.
	CCP1CONbits.CCP1M = 0x0;		//turn off the CCP module stop generating 38Khz singal
	__delay_us(4490);				//wait for ~4.5ms  the value 4490 is compensated with the next instrucitons execution timing , it helps to keep precise timing. as described avobe
	sendByte(address);				//send address byte. (sendByte functions should not be called independently, only sendFrame should call it)
	sendByte(~address);				//send address logical invert
	sendByte(command);				//send command
	sendByte(~command);				//send command logical invert
									//addres and command is sent now send the end of message bit
	CCP1CONbits.CCP1M = 0xC;		//Start generating 38Khz singal
	__delay_us(561);				//wait for ~562.5us again value 561 is compensated with the next instrucitons timing
	CCP1CONbits.CCP1M = 0x0;		//stop generating 38Khz singal.
	__delay_ms(40);					// wait for the Data Frame time.
void sendByte(unsigned char byte)	// this function is called only by the sendFrame , to send each byte of data total 4bytes.
	unsigned char i;				//variable to hold the counter vlaue
	for(i=8 ;i>0;i--)				//loop to send 8 individual bits.
		CCP1CONbits.CCP1M=0xC;		//Start generating 38Khz singal
		CCP1CONbits.CCP1M=0x0;		//stop generating 38Khz singal
		if(byte & 0x80)				// as you have already noticed , this is example we send MSB first order.
		{							// check for MSB bit if it is 1 then delay for 1.6875ms if it is zero then delay for 562.5us
		__delay_us(1686);			//delay for ~1.6875 ms again value 1686 is compensated with the next instrucitons timing
		else
		__delay_us(558);			//wait for ~562.5us again value 558 is compensated with the next instrucitons timing
		byte = byte <<1;			//get the next lsb into msb (shift left the byte)
void sendRepeate()
	__delay_us(2245);				//wait for 2.25ms
	__delay_us(556);				//wait for ~562.5us
	__delay_us(96187);				//delay for 96.187 ms before sending the next repeate code
And receiver code
// Global includes
#include <htc.h>
							 				// and total bits 32 and 2 leading pulse */
void main()
				   break;
				   break;
				   break;
				   break;
				   RELAY2 = 0;
				   RELAY3 = 0;
				   RELAY4 = 0;
				   break;
		case 0xAF: RELAY1 = !RELAY1;		//Toggle relay 1
				   break;
		case 0x27: RELAY2 = !RELAY2;		//Toggle relay 2
				   break;
		case 0x07: RELAY3 = !RELAY3;		//Toggle relay 3
				   break;
		case 0xCF: RELAY4 = !RELAY4;		//Toggle relay 4
				   break;
		case 0x4F: RELAY1 = 0;				//Turn off all the relay
				   RELAY2 = 0;
				   RELAY3 = 0;
				   RELAY4 = 0;
				   break;
		default :
					break;
		EECON2 = 0x55;			//2
unsigned char pin;
if
			necpoj++;
			necpoj++;
					else
					dataready =1;
					else
					dataready=0;
			necpoj=0;
	else
else
	else
	address 	= 0xFF;
	notaddress 	= 0xFF;
	command 	= 0xFF;
	notcommand 	= 0xFF;
	dataready 	= 0x000;
timer++;
and proteus file
  • test.rar
hello FVM thanks for reply ,
but i still not get smoother result . and actually my receiver interrupt completely receive bits of 1 and 0 . but problem is didn't detect Address and Command . so how to resolve address and command of NEC decoder to operate my relay ?
- Did you achieve a IR send signal with frequency 38 kHz, 50% duty cycle?
- Did you tune the IRLINK paramters to get a continuous low pulse per IR burst? You need to chenge the frequency in the component properties.
YES FVM i send 38khz signal at 50% duty cycle.
and yes i have change the IRLINK parameters to 38khz frequency.
but output of relay is not coming means relay is not triggered.
I didn't specifically ask if you changed the IRLINK parameter to 38 kHz, I suggested to check if the received waveform is actually as expected. If so, you gonna debug the receiver software.
My problem is i am not able to operate relay using remote.
below is the Hi-Tech C project files + Proteus file + compiled .hex files of transmitter and receiver
  • Simulation.rar
  • Receiver Code.rar
  • Remote Code.rar
Just a few observations.
1. Your 12F615 /MCLR is pulled up to 3V but your VDD is still on 5V.
2. On the properties of IRLINK, the default is 40KHz. Are your TX/RX software based on 40KHz or 38KHz?
3. I see that all 4 relays are operating before any button is pressed when simulation starts.
Have you tried connect directly the output of 615 to the input of 675 without going through the IRLINK?
Just my 2 cents
Allen
Your finally presented code is still sending IR bursts of about 14 kHz as reported in post #6. That's a bit disapponting.
It seems to me as Proteus bug in simulating the PIC12F timer. As one symptome, PR2 ist reset to FF spontaneously. I fear, there's nothing we can do about. (Or maybe you can try to refresh the timer settings in main loop).
A circuit will hopefully work.
yes My 12f615 /MCLR is pulled up to 3v and vdd is also 3V.
yes now i have test with 38kHz but still getting problem to operate relay .
yes all relay operate as simulation start . and yes i tried to connect directly 615 and 675 but same problem arise (Relay is not triggered) .
ok FVM i have test and answer here.
I tried your simulation but I don't see relay operation initially and also I don't see IR bursts on Oscilloscope when buttons are pressed.
