pnsakanjankumar
Member level 2
Can anyone suggest a way to obtain data stream at the receive end(IR receiver)
apart from using 'pic' chip
Thanks.
Thanks.
Thanks for your reply.
Suppose if am sending a data stream of 110011 then IR(transmitter) will be on for '11' and off for '00' but At the receiver since we are using 555 timer in monostable mode it needs a trigger.
Here it is receiving '1' constantly sent by transmitter thereby that data '1' is not able to trigger 555 then how can i get data stream '1'.
For '0' there is no need for trigger.
Can You tell me a way such that it sends a trigger to receiver when data stream to be sent is '1'.
Thanks.
Anjan.
