[SOLVED] Inverting DC/DC Converter
kasamiko
Full Member level 3
Philippines
I'm looking for a design of inverting DC/DC converter using MC34063.
+12VDC IN and -12VDC OUT..at least 150mA.
I've seen some design but limited to 5VDC input only..
TIA
I'm not sure if that 5V limit with -12V out is inherent to the MC34063... I can't find anything in the datasheet that suggest the input on their example inverting converter can't go up to +12V.
One option is to use an external Pfet, driven by the MC34063 output as an open collector pull down. That should allow a much wider operating range.
Maximum 34063 I/O voltage differential is 40 V, there is a understandable reason, why the input voltage should be limited to 5 or 6 V, probably except for timing capacitor + inductor dimensioning specific. As in other applications, 34063 performance isn't mind blowing. Before trying to pimp it up with an external power stage, I would look for a more recent switcher chip.
Hi guys!
I'm stuck to MC34063 due to parts availability..
I'll try the ckt posted by tpetar and try to power it with 12VDC..
I'll post the result later..
BR
