inverting and noninverting mosfet drivers
manishanand14
Full Member level 4
Bangalore ,India
Hello Everyone!
Please provide me some explanation about inverting and noninverting mosfet drivers.
Can I use them interchangebly?
Can I use TPS2829 instead of TPS2817 to increase the input voltage range in the given circuit?
Also can I replace the given p-channel MOSFET IRF7406 with a suitable n-channel MOSFET in the given ckt.?
No. The present circuit demands a non-inverting driver, by TL5001 output signal polarity.
No, because they have the same driver output voltage rating of 14V. An additional input pullup resistor would be needed with TPS2829.
Not easily. N-channel MOSFET requires a bootstrap driver with suitable start-up circuit.
Is it necessary to use a non-inverting driver with a p-channel MOSFET and vice versa.
Can I use UCC27519 instead of TPS2817.
Many drivers offer inverting and noninverting inputs with
A*!B logic. Then you can use them in whatever polarity
your larger assembly wants.
You'd want to be looking more at the subtleties, such as
what the output does during undervoltage lockout (keep
your power switches off, or the totem pole such that the
inductor sees zero voltage / current, is a good idea if you
like to not burn things out at startup).
