sooyassine1
Newbie level 6
- Joined
- Jul 25, 2012
- Messages
- 13
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,374
I'm designing an LC filter for a 3 phase sine wave inverter (7KVA 230V 50Hz) , my inverter is controlled by an SPWM, there are my output quality specifications : THDi<3% & THDv<3% .
I ve calculated the cut off frequency in order to attenuate the first significant harmonic which appears on the carrier frequency(6150Hz), the gain of this harmonic is about 40dB , so with a 2nd order filter i should cut off at 615Hz.
but i see that it s not the good way to find the cut off frequency , because it don't take on consideration the specifications of THDi & THDv.I can do that only on simulation!!! I want to know if there is a method or a document which can help me in this topic
