khansaab21
Hello guys. Up till now i have been using the built in serial port and default serial protocol available in microcontrollers (like PIC). Since default state of the Tx (transmit) pin is HI, i need to use the inverted mode i.e. i need the default state of the Tx pin to be low. How could i implement it with the serial pins available in the controller.
Can only one PNP transistor could serve the purpose or is there anyother direct method??
