cupoftea
Advanced Member level 5
We have a square wave oscillator....sometimes we want to pass through the signal itself, and sometimes we want to pass through the inverted signal. We want to change between the two with a single manual switch.
Can you think of any easier ways than the attached. I guess an analog changeover switch is good but they are often nil stocked....if i put one on the test pcb, its bound to go nil stocked.
Any other ways?
LTspice and pdf attached of the "bad" way
Any other ways?
