<INVALID OPERATOR> must have constant operands or first operand must be power of 2
dksagra
Junior Member level 1
india
HELLO, PLEASE HELP ME...WHEN M RUNNING THIS PROGRAM...I FOUND ONE ERROR...
ERROR ARISE AT K_TEMP(U FIND K_TEMP AT 8 LINE FROM THE BOTTOM)......
ERROR "Operator <INVALID OPERATOR> must have constant operands or first operand must be power of 2"
THIS ERROR IS ARISING...PLEASE HELP ME OUT...
I M SENDING THE WHOLE PROGRAM...
Library IEEE ;
Use IEEE . std_logic_1164 .All ;
Use IEEE .numeric_std .All ;
Package matrix_types Is
Type matrix_2x2 Is Array (1 to 2, 1 to 2) Of Signed (31 downto 0); --row x column
Type matrix_2x1 Is Array (1 to 2) Of Signed (31 downto 0); --row x column
Type matrix_1x2 Is Array (1 to 2) Of Signed (31 downto 0); --row x column
End Package matrix_types ;
Library IEEE ;
use IEEE.std_logic_signed.all;
use IEEE.std_logic_unsigned.all;
Use IEEE .std_logic_arith .All ;
Use work .matrix_types .All ;
Use std. textio .All ;
Entity kf_top Is
Port ( z_position : In Signed (31 downto 0);
reset :In Std_logic ;
position , velocity : Out Signed (31 downto 0));
End kf_top ;
Architecture kf_behav Of kf_top Is
--* Function to multiply two 2x2 matrices *
Function matrix_mult_2x2 (A,B: matrix_2x2 )
Return matrix_2x2 Is
Variable result : matrix_2x2 ;
Variable func_temp1 : Signed (63 downto 0) :=( OTHERS => '0');
Begin --Begin function code .
For i In 1 to 2 Loop
For L In 1 to 2 Loop
For j In 1 to 2 Loop
func_temp1 := (A(i,j)*B(j,L)) + func_temp1 ;
End Loop ;
result (i,L) := func_temp1 (47 downto 16) ;
func_temp1 :=( OTHERS => '0');
End Loop ;
End Loop ;
Return result ;
End matrix_mult_2x2 ;
--* Function to add two 2x2 matrices *
Function matrix_add_2x2 (A,B: matrix_2x2 )
result (i,j) := A(i,j)+B(i,j);
End Loop ;
End Loop ;
Return result ;
End matrix_add_2x2 ;
--* Function to add a scalar to a 2x2 matrix *
Function matrix_add_int_2x2 (A: matrix_2x2 ;B: Signed (31 downto 0))
result (i,j) := A(i,j)+B;
End Loop ;
End Loop ;
End matrix_add_int_2x2 ;
--* Function to multiply a 2x2 with a 2x1 matrix *
Function matrix_mult_2x2_2x1 (A: matrix_2x2 ;B: matrix_2x1 )
Return matrix_2x1 Is
Variable result : matrix_2x1 ;
func_temp1 := (A(i,j)*B(j)) + func_temp1 ;
End Loop ;
result (i) := func_temp1 (47 downto 16);
func_temp1 :=
( OTHERS=> '0');
End Loop ;
Return result ;
End matrix_mult_2x2_2x1 ;
--* Function to multiply a 1x2 with a 2x2 matrix *
Function matrix_mult_1x2_2x2 (A: matrix_1x2 ;B: matrix_2x2 )
Return matrix_1x2 Is
Variable result : matrix_1x2 ;
( OTHERS=> '0');
func_temp1 := (A(j)*B(j,L)) + func_temp1 ;
End Loop ;
result (L) := func_temp1 (47 downto 16);
End Loop ;
Return result ;
End matrix_mult_1x2_2x2 ;
--* Function to multiply a 1x2 with a 2x1 matrix *
Function matrix_mult_1x2_2x1 (A: matrix_1x2 ;B: matrix_2x1 )
Return Signed Is
Variable result : Signed (63 downto 0) :=( OTHERS => '0');
result := (A(j)*B(j)) + result ;
End Loop ;
Return result (47 downto 16);
End matrix_mult_1x2_2x1 ;
--* Function to multiply a 2x1 and a 1x2 matrix *
Function matrix_mult_2x1_1x2 (A: matrix_2x1 ;B: matrix_1x2 )
Variable func_temp1 : Signed (63 downto 0);
func_temp1 := (A(i)*B(L));
End Loop ;
end loop;
Return result ;
End matrix_mult_2x1_1x2 ;
--* Function to multiply a 2x1 matrix and a scalar *
Function matrix_mult_2x1_int (A: matrix_2x1 ;B: Signed (31 downto 0))
func_temp1 := A(i)*B;
End Loop ;
Return result ;
End matrix_mult_2x1_int ;
--* Function to add a 2x1 to a 2x1 matrix *
Function matrix_add_2x1_2x1 (A: matrix_2x1 ;B: matrix_2x1 )
result (i) := A(i)+B(i);
End Loop ;
Return result ;
End matrix_add_2x1_2x1 ;
--* Function to subtract two 2x2 matrices *
Function matrix_subtract_2x2 (A,B: matrix_2x2 )
result (i,j) := A(i,j)-B(i,j);
End Loop ;
End Loop ;
Return result ;
End matrix_subtract_2x2 ;
--* Function to return the diagonal ( diag ) of a 2x2 matrix *
Function diag_2x2 (A: matrix_2x2 )
result (i) := A(i,i);
End Loop ;
Return result ;
End diag_2x2 ;
--* Begin main process . *
Begin
Process ( z_position , reset ) Is
Constant dt : Signed (31 downto 0) :="00000000000000000001100110011001";
--R is the measurement noise covariance .
Constant R : Signed (31 downto 0) :="00000000000010100000000000000000";
--Q is " dynamic noise strength " ( process noise covariance ).
Constant Q : Signed (31 downto 0) :="00000000011001000000000000000000";
--G is the noise injection model .
--This was intended to be 2 rows , 1 column but is represented as1 row , 2 columns .
Constant G : matrix_2x1 :=
("00000000000000000000000000000000",
"00000000000000010000000000000000");
--1 row , 2 columns .
Constant B : matrix_2x1 :=
Constant Bd : matrix_2x1 :=
("00000000000000000000000101000111",
"00000000000000000001100110011001");
Constant H : matrix_1x2 :=
("00000000000000010000000000000000",
"00000000000000000000000000000000");
Constant H_prime : matrix_2x1 :=
Constant F : matrix_2x2 :=
(("00000000000000000000000000000000",
"00000000000000010000000000000000"),
"00000000000000000000000000000000"));
Constant phi : matrix_2x2 :=
(("00000000000000010000000000000000",
"00000000000000000001100110011001"),
"00000000000000010000000000000000"));
Constant phi_prime : matrix_2x2 :=
"00000000000000000000000000000000"),
("00000000000000000001100110011001",
Constant Qd : matrix_2x2 :=
(("00000000000000000000100010000110",
"00000000000000001000000000000000"),
("00000000000000001000000000000000",
"00000000000010100000000000000000"));
Constant Gd : matrix_2x2 :=
--* Definition of Variables *
Variable x : matrix_2x1 :=
Variable P : matrix_2x2 :=
(("00000000000000000100000000000000",
"00000000000000000100000000000000"));
Variable A : signed (31 downto 0);
Variable residual : Signed (31 downto 0);
Variable K : matrix_2x1 ;
Variable K_temp : signed (33 downto 0);
variable e : signed (33 downto 0);
variable e1 : signed (31 downto 0);
Begin
If reset = '1' Then
x :=
P :=
End If;
x := matrix_mult_2x2_2x1 (phi ,x);
P := matrix_add_2x2 (( matrix_mult_2x2 (matrix_mult_2x2 (phi ,P),phi_prime )),Qd);
A := matrix_mult_1x2_2x1 ( matrix_mult_1x2_2x2 (H,P),H_prime )+R;
K_temp := "0100000000000000000000000000000000" /A;
K := matrix_mult_2x1_int ( matrix_mult_2x2_2x1 (P,H_prime ),K_temp (31 downto 0));
residual := z_position - matrix_mult_1x2_2x1 (H,x);
x := matrix_add_2x1_2x1 (x, matrix_mult_2x1_int (K,residual));
P := matrix_subtract_2x2 (P, matrix_mult_2x2 (matrix_mult_2x1_1x2 (K,H),P));
position<= x(1);
velocity<= x(2);
End Process ;
End kf_behav;
Re: <INVALID OPERATOR> must have constant operands or first operand must be power of
heres a big failure:
Use IEEE .numeric_std.All ;
You cannot use both in the same file, as you get conflicts. Delete std_logic_arith as it is non-standard.
You dont say where the error is.
And please use the code tags.
thanks for the reply...
as you are suggesting i did the same before also..but still there were an error...
please have a look in K_TEMP...there is an error...
regards
Your entire design is asynchronous, and looks alot like software. So the biggest, problem in your design is a lack of clock.
I suggest you delete your code, and draw, on paper, the circuit you are trying to achieve. VHDL is NOT a programming language.
ok thanks...
lets wait others are able to understand my problem or not...
ok please tell me one thing...in cut short
there is,
Variable K_temp : signed (31 downto 0);
A has some signed value of 31 downto 0 , already calculated
now,
K_temp := "010000000000000000000000000000000" / A;is it possible?
when i m doing this, <INVALID OPERATOR> must have constant operands or first operand must be power of 2..this message is occuring
it is expecting A to be a constant AND a power of 2, then it is a simple bitshift. With A being any number, it cannot do that and needs a divider. Dividers need to be clocked, and ones that run at decent clock speeds need a few pipeline stages to complete.
But the main problem is you're writing as if VHDL is a programming language, when actually, its a description language (ie. you need to know what the circuit is before you write the code!)
