Interview ques? which was asked. Need some help in solving
gmailbond
Junior Member level 1
Bangalore
1.One inverter is connected to 20 inverters. Wp/Wn of all 20 inverters is 2/1. Scale the driver inverter appropriately.
2.What are the critical issues during synchronising between 2 clock domains?
3.Two capacitors in parallel with a switch in between. Initially switch is open and C1 is charged to 10V. After that the switch is closed. Find the voltage on C2.
4.Design a logic to count the no. of 1's in an 8 bit register?
research_vlsi
Re: Interview ques? which was asked. Need some help in solvi
Solution for 4 th Ques
declare count=4'b0; data is ur 8 bit input
for(i=1;i<=7;i=i+1)
if(data==1)
count=count + 1;
else
count=count;
Count is ur output.
LECS
Newbie level 5
Perhaps 4 is in a list of standard interview questions somewhere, because I was asked that at an interview for a PC software post. My answer was that it depended on project priorities such as small code, fast code, or easy-to-maintain maintain code. I presented solutions based around bit-shifting, a lookup table and bit-by-bit checking.
shanmugaveld
Bangalore
for 4th Ques
count : std_logic_vector(3 downto 0);
count <= reg(0) + reg(1) + reg(2) +
reg(4) + reg(5) + reg(6) +
reg(3) + reg(7) + reg(8);
arjun1110
Bangalore,India
For the third question:
The voltage on C2 will be five volts. As soon as switch is closed the charge stored on C1 will start discharge till C2 is equal charged.
Charge on parallel plate capacitor
Q=CV -----------> 1
V=Q/C ----------->2
When the switch is closed, charge on each capacitor
Q1=Q2=Q/2 ---->3
Voltage on capacitor C2 is
V2=Q2/C
=Q/2C (substituting value of Q from equation number 3)
=V/2 (Replacing Q/C from equation # 2 )
=10/2
=5 Volts
Regards
gharuda
Member level 3
Bengaluru
1) the size of the inverter could depended upon the speed. ie rise time and fall time of the circuit
so the 20 inverters are driven by one inverter. in this case all of the inverter are of same size the delay from the input to the output is
T phl=T plh =(Rn +Rp)(C out+20Cin) ,so from Tphl and Tplh size of the inveter can be design
Added after 10 minutes:
1 operating frequency: when two domains are of different frequency.
2 phase : frequency been same but their phase differ.
eecs4ever
Full Member level 3
Analog Environment
1.
the total load size is 40/20, so our driver should be roughly 1/3 to 1/4 the size. here i think i'd go with a 14/7 inverter.
3. arjun110 is correct only if C1 == C2.
Q= CV , Q here is 10 * C1, C=C1+C2, so
Vout = 10*C1/(C1+C2)
jorgito
Full Member level 4
Argentina
Hello,
In the proposed solution to question 3, it is valid only if capacitors are the same value, condition I do not see stated in the question.
Regards!
arjun1110
Bangalore,India
for question three.
Irrespective value of C2, voltage on C2 will be 5volts.
Reason:
Assume two water tanks t1 and t2 of different capacity with the diameter of the two tanks remains same, only height varies and both tanks are connected at the bottom through tap.
Now assume tank t1 is filled with ten liters of water and the tap is made to open, so what amount of water will be discharged into t2? It will be five liter only even though it is has higher capacity to store.
Any other answer with reason will be always welcome.
jorgito
Full Member level 4
Argentina
Hello arjun1110,
Beware of analogies, specially if you dont use the correct one. The electrical capacitance is better modeled as tank's diameter than its height.
In your derivation, you state that Q1=Q2, when you must say V1=V2, being the capacitors in parallel.
If you want convince yourself, you can carge a 1uF capacitor and discharge it over a 1000uF.
If you prefer a more mathematical way, proceed calculating the initial stored energy in the small capacitor and the sum of energies on both after discharging.
With the given values, E1= (1 e-6 F * 10V**2)/2 = 50uJoule
After discharging, and assuming as you say that both capacitors have 5 V across them, the energy stored in the big capacitor will be:
E2 = (1 e-3 F * 5V**2)2 = 12.5 mJoule
Even desregarding the energy still stored in the small capacitor, the final energy in the system is orders of magnitude greater than the initial energy.
Regards
arjun1110
Bangalore,India
Hi gmailbond,
When the switch is closed, will the supply voltage is still connected across C1 and C2 ?
Or the circuit is only two capacitor connected in parallel and capacitor C1 is initial charged to 10v before closing the switch and suuply is removed?
Please will you confirm.
Hi jorgito,
If he says yes to first one then voltage on C2 will be 10V.
Or in case 2 what will be voltage on C2?
Regards,
gmailbond
Bangalore
Hi arjun,
The question was as it is with no other info given ,u need to assume the values for the capacitor,when we asked the interviewer.
So like wat is the voltage of C2 with the assumed conditions
1.C1=C2
2.C1≠C2
