jeevan19
Newbie level 1
hi,i am new to avr programming, i tried this below code,,where in my main program i make sm bits toggle for 5 times,,and i give an external interrupt to INT1. In my interrupt routine,,i just give some delay of 10 secs..i tried in proteus. my interrupt is not called when i give high signal to int1 pin,..i tried these interrupts logic 1.any logic change makes interrupt request
2.rising edge gives interrupt request
3.falling edge gives interr request...........but none worked out,,SO PLEASE HELP ME IN THIS
my code,,,
my code,,,
#include <avr/io.h>
#include <avr/interrupt.h>
#define F_CPU 16000000UL
#include <util/delay.h>
void delay_ms(unsigned int d)
_delay_ms(d);
ISR(INT1_vect)
_delay_ms(6000);
_delay_ms(4000);
int main (void)
unsigned int i,j;
DDRC = 0xF0; //IN PORTC upper 4 bit is output and lower 4 bit is input
DDRD = 0X00; //portd as input
while(1)
if(bit_is_clear(PINC,0)) //if PORTC 0 PIN IS LOW
for(i=0;i<4;i++)
PORTC=0X40;
_delay_ms(1000);
PORTC=0X00;
_delay_ms(1000);
GICR = 1<<INT1; // Enable INT0
MCUCR = 1<<ISC11 | 0<<ISC10; // Trigger INT0 on any logic change
sei(); //enable global interrupt
for(j=0;j<4;j++)
_delay_ms(2000);
PORTC=0X80;
_delay_ms(2000);
PORTC=0X00;
else
PORTC=0X00;
return 1;
