asking
Full Member level 5
- Joined
- Sep 21, 2010
- Messages
- 279
- Helped
- 6
- Reputation
- 12
- Reaction score
- 6
- Trophy points
- 1,298
- Activity points
- 3,377
unsigned char x;
// Interrupt Handler
void interrupt()
// RB Port Change Interrupt
if(PIR1.RBIF == 1) // if the RB Port Change Interrupt flag is set...
PORTA.F1 = ~PORTA.F1;//LED on/off on press of switch
x = PORTB; // Need to read or write to the port to clear mismatch condition
PIR1.RBIF =0;
// code starts here...
void main()
TRISA = 0b00000000;
TRISB = 0b00100000; //RB5 defined as input and push switch connected to it
// Set Interrupt Enable bits
INTCON.RBIE = 1; // bit 3 RB Port Change Interrupt Enable
//Set global Interrupt Enable bits
INTCON.GIE = 1; // global interrput enable
while(1) //endless loop
I just want to toggle led on PortA1 on/off when i press push button on RB5 ...i have made the above code but i don't know why its not working please help...
