Udit_agarwal
Newbie level 5
Hi forums,
Following is the hysteresis loop of a standard memristor:
![index.png index.png](https://www.edaboard.com/data/attachments/80/80292-b954db286c38115137b227289ff641d8.jpg)
Please note that, the red one is for lowest frequency and black for highest frequency.
From the graph, one can take the following observations:
1> As frequency increases, area of graph decreases
2> With increase in frequency, graph tends to tilt more towards x axis
3> Slight deformity of the red curve at higher VI values.
I tried interpreting these observations, keeping in mind memristors Piecewise linear model(Is that a correct assumption?).
If second observation is correct:- Memristance decreases with increase in frequency and at frequency tending to infinity, it acts like a constant value resistance whose value should be Minimum possible value of memristance. Right?
Also, I need a bit explanation for 3 observation. I'm unable to figure out it's reason.
Thanks,
Udit agarwal
Thanks,
Udit agarwal
