[SOLVED] Internal EEPROM ( PIC16F877A ) using microchip xc8 compiler
bhoobalan
Member level 1
Member level 1
Hi friends,
I want to store LED values in Internal EEPROM using PIC16F877a in microchip xc8 compiler in c codes. I am struggling to do it. Pls help me with example c codes with circuit diagram along with simulation result.
If you look in the include directory of the compiler you will see a header file 'eeprom_routines.h'
In it you will find function prototypes:
/* library function versions */
extern void eeprom_write(unsigned char addr, unsigned char value);
extern unsigned char eeprom_read(unsigned char addr);
If you include 'xc.h' in your program, this header file is loaded.
So read write eeprom functions are available for you to use supplied by the compiler.
Thanks for the reply btbass
i can't able to find it..........
will u pls post the c code for xc8 compiler .............
You just need to include <xc.h>
Then you can use the functions anywhere in your program.
Thanks friends,,,,,,,,,,,,,,
Got the output...........
Good work........
I love this forum.........
