pashok84
Member level 4
Hi All,
I am trying to interface MSP430 microcontroller and Telit GT863-PY module. I am facing a problem. microcontroller is not able to communictate with gsm module.
When i test the microcontroller with PC serial port it is working and gsm module is also working individual with PC.
when i connect microcontroller with GSM module, it is not working. I thought it might be because of flow control, as in microcontroller side only 3 pins are connected.
After disabling Flow control also problem exists.
Can anyone give sugesstion to debug further, or anyone faced similar issue earlier.
Setup
Microcontroller <=> RS232 cable <=> GSM modem.
Thanks and Regards,
Ashok Kumar P
Setup
Thanks and Regards,
Ashok Kumar P
