I am trying to interface a tc35i gsm module .
As datasheet I connected:
1-5 -> BAT+
6-10 -> GND
18(RXD0) -> max232 (12-R1Out)
19(TXD0) -> max232 (11-T1IN)
and IGT to a circuit which trying to turn on the tc35i.
But I cant get anything hyper terminal.
When I set baud rate on hyper terminal to 115200 I and when I type I see something which is not correct for example when I type A I see H as echo.
I would appreciate if you can help me.
Hi again,
first problem was about current and now solved.
I have another issue which is :
When there is no SIM card I can send AT command and ... but when I input SIM card I see LED blink 4-5 times and turn off , during this blinking I can send AT commands (which is about 3-4 Seconds) then stopped.
Depending on how the device was set up - maybe its trying to register on the network - in which case it will draw large current spikes - check current again.
