syedshan
Advanced Member level 1
- Joined
- Feb 27, 2012
- Messages
- 463
- Helped
- 27
- Reputation
- 54
- Reaction score
- 26
- Trophy points
- 1,308
- Location
- Jeonju, South Korea
- Activity points
- 5,134
Dear all,
Since I am using 3rd party fpga hardware(which utilizes xilinx V6 FPGA) for my design with PCIe communication.
They have defined their own API and dlls through which we can communicate with the program.
To receive and send data the statement they have defined are as follows as defined in their manual.
Now problem is as follows. When I tried a sample program of adder made in VHDL and operate through Visual C++ accordingly it works fine when : I first send data through _4FM_SendData and then receive the result through _4FM_ReceiveData
But When I only operate the _4FM_ReceiveData it should at least get some garbage value, but I am unable to recieve any data. Infact it says unable to communicate through the device.
Is there any idea fellows can share why and how the computer and the hardware commincate each other.
I have posted below the major parts of the code.
Waiting for the reply.
Bests,
Shan
" _4FM_OpenDevice
_4FM_error_t _4FM_CALL _4FM_OpenDevice (_4FM_DeviceContext * ctx, const char *type, int devno);
Parameters:
ctx: the device context to operate on.
type: the type name of the device to open.
devno: the device number to open for the device specified by type.
_4FM_error_t _4FM_CALL _4FM_ReceiveData(_4FM_DeviceContext *ctx, void *buffer, unsigned long count);
Receive data from a 4FM family
Parameters:
buffer : pointer to memory where to store data
count: number of bytes to receive
_4FM_error_t _4FM_CALL _4FM_SendData(_4FM_DeviceContext *ctx, void *buffer, unsigned long count);
Parameters:
buffer : pointer to memory where to send data
count: number of bytes to send
// DMA ( Direct Memory Access ) implementation requires 4k aligned buffers in the memory.
// we allocate both buffers.
dma_buffer_in = (char *)_aligned_malloc(_MEMORY_SIZE, 4096);
dma_buffer_out = (char *)_aligned_malloc(_MEMORY_SIZE, 4096);
// We initialize the buffer with 0
memset(dma_buffer_out, 0x00, _MEMORY_SIZE);
// Send the data to the hardware using direct memory address operations
api_status = _4FM_SendData(&dev_ctx, dma_buffer_out, _MEMORY_SIZE);
if(api_status!=_4FM_OK) {
printf("Could not send random data to the hardware device...\n");
exit_handler(dma_buffer_in, dma_buffer_out, &dev_ctx);
// Receive the data from the hardware using direct memory address operations
api_status = _4FM_ReceiveData(&dev_ctx, dma_buffer_in, _MEMORY_SIZE);
printf("Could not receive random data from the hardware device...\n");
Bests,
Shan
