From the datasheet of the Transceiver, Pin 4 and 5 are used for USART communication. Thery are TTL compatible, i.e. works with digital 5v. Hence the Tx and Rx of the module can be connect directly to the Rx and Tx pins of the Arduino (digital 1 & 0 pins). the module can be powered from the arduino itself by connecting the Vcc and GND pins of the module to the 5v and Gnd pins of the arduino... Not to forget to make the enable pin of the module High (5v) !!...
Hope you know the rest about the programming part. If not post your queries !
thank you for your reply...
We have done programming using arduino software serial,but transmitted data is not received. Can you please help us with the programming part too?
