banh
Advanced Member level 1
how do we go about interfacing an analog input into the microcontroller ADC pin?
- current limiting? (depending on the max current allowed at the pin)
- capacitors to filter out noise?
- i've seen a circuit that before going into the pin, the analog signal goes through a resistor (quite small about 22 Ohm). THe resistor is said to provide "damping effect". Really dont understand what this means..
