[PIC] Interfacing DHT11 to Pic using xc8 compiler
Sarit
Newbie level 2
Newbie level 2
Hey there, I've been trying to interface a DHT11 sensor to a pic18F4550 and coding with xC8 compiler. Actually I've modified it from a website. I've successfully loaded a hex file into the MCU but the LCD only displays zero humidity and zero temperature. I've checked and my circuit has no problem. The DHT11 sensor is also working, I guessed the problem may be with the software... Can someone point out where I'm missing it. Thanks.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
/* MCU Definitions */
#include <p18cxxx.h>
#include <string.h>
#include <plib/delays.h>
#include <stdio.h>
#include <plib/xlcd.h>
// PIC18F4550 Configuration Bit Settings
// 'C' source line config statements
#include <xc.h>
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG1L
#pragma config PLLDIV = 5       // PLL Prescaler Selection bits (Divide by 5 (20 MHz oscillator input))
#pragma config CPUDIV = OSC1_PLL2// System Clock Postscaler Selection bits ([Primary Oscillator Src: /1][96 MHz PLL Src: /2])
#pragma config USBDIV = 2       // USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes from the 96 MHz PLL divided by 2)
// CONFIG1H
#pragma config FOSC = INTOSCIO_EC// Oscillator Selection bits (Internal oscillator, port function on RA6, EC used by USB (INTIO))
#pragma config FCMEN = OFF      // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF       // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = OFF       // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOR = OFF        // Brown-out Reset Enable bits (Brown-out Reset disabled in hardware and software)
#pragma config BORV = 3         // Brown-out Reset Voltage bits (Minimum setting)
#pragma config VREGEN = OFF     // USB Voltage Regulator Enable bit (USB voltage regulator disabled)
// CONFIG2H
#pragma config WDT = OFF        // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 32768    // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = ON      // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
#pragma config PBADEN = OFF     // PORTB A/D Enable bit (PORTB<4:0> pins are configured as digital I/O on Reset)
#pragma config LPT1OSC = OFF    // Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = OFF      // MCLR Pin Enable bit (RE3 input pin enabled; MCLR pin disabled)
// CONFIG4L
#pragma config STVREN = ON      // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = OFF        // Single-Supply ICSP Enable bit (Single-Supply ICSP disabled)
#pragma config ICPRT = OFF      // Dedicated In-Circuit Debug/Programming Port (ICPORT) Enable bit (ICPORT disabled)
#pragma config XINST = OFF      // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
// CONFIG5L
#pragma config CP0 = OFF        // Code Protection bit (Block 0 (000800-001FFFh) is not code-protected)
#pragma config CP1 = OFF        // Code Protection bit (Block 1 (002000-003FFFh) is not code-protected)
#pragma config CP2 = OFF        // Code Protection bit (Block 2 (004000-005FFFh) is not code-protected)
#pragma config CP3 = OFF        // Code Protection bit (Block 3 (006000-007FFFh) is not code-protected)
// CONFIG5H
#pragma config CPB = OFF        // Boot Block Code Protection bit (Boot block (000000-0007FFh) is not code-protected)
#pragma config CPD = OFF        // Data EEPROM Code Protection bit (Data EEPROM is not code-protected)
// CONFIG6L
#pragma config WRT0 = OFF       // Write Protection bit (Block 0 (000800-001FFFh) is not write-protected)
#pragma config WRT1 = OFF       // Write Protection bit (Block 1 (002000-003FFFh) is not write-protected)
#pragma config WRT2 = OFF       // Write Protection bit (Block 2 (004000-005FFFh) is not write-protected)
#pragma config WRT3 = OFF       // Write Protection bit (Block 3 (006000-007FFFh) is not write-protected)
// CONFIG6H
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) are not write-protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot block (000000-0007FFh) is not write-protected)
#pragma config WRTD = OFF       // Data EEPROM Write Protection bit (Data EEPROM is not write-protected)
// CONFIG7L
#pragma config EBTR0 = OFF      // Table Read Protection bit (Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR1 = OFF      // Table Read Protection bit (Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR2 = OFF      // Table Read Protection bit (Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks)
#pragma config EBTR3 = OFF      // Table Read Protection bit (Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks)
// CONFIG7H
#pragma config EBTRB = OFF      // Boot Block Table Read Protection bit (Boot block (000000-0007FFh) is not protected from table reads executed in other blocks)
#define _XTAL_FREQ 4000000    //Chip FREQUENCY
/* DHT11 I/O Macros  */
#ifndef DHT11
#define DHT11_TRIS  TRISDbits.TRISD1
#define DHT11_PIN  PORTDbits.RD1
#endif
/* Globals   */
char dht_dat[10]; // Output data will be here
unsigned char GlobalErr = 0;
unsigned char Buffer[20];
unsigned char Buffer1[20];
unsigned char t[20];
unsigned char n[20];
/* Function Prototypes */
void dht_init(void);
unsigned char dht_poll(void);
void read_dht(void);
//a simple delay function
void Wait(unsigned int delay)//delay for 100ms
    for(;delay;delay--)
        __delay_us(100);
/* Functions           */
void dht_init() {
    Delay1KTCYx(5); // 1ms
    DHT11_TRIS = 0;
    DHT11_PIN = 1;
unsigned char dht_poll() {
    unsigned char i = 0;
    unsigned char result = 0;
    DHT11_TRIS = 1;
    for (i = 0; i < 8; i++) {
        while (DHT11_PIN == 0);
        Delay10TCYx(15); //30us
        if (DHT11_PIN == 1) {
            result |= (1 << (7 - i));
        while (DHT11_PIN == 1);
    return result;
void read_dht() {
    unsigned char dht_in;
    unsigned char i;
    GlobalErr = 0;
    dht_init();
    DHT11_PIN = 0;  //port value is low
    Delay1KTCYx(90); // 18ms
    DHT11_PIN = 1;  //port value is high
    Delay100TCYx(1); // 20-40us
    DHT11_TRIS = 1; //make pin input
    dht_in = DHT11_PIN;
    if (dht_in) {
        GlobalErr = 1;
        return;
    Delay100TCYx(4); // 80us
    dht_in = DHT11_PIN;
    if (!dht_in) {
        GlobalErr = 2;
        return;
    for (i = 0; i < 5; i++) {
        dht_dat[i] = dht_poll();
    DHT11_PIN = 1;
    DHT11_TRIS = 0;
/* _user_putc()
 * Check for more information :
 * C18 Standart Libraries "Output Streams"
int _user_putc(char c) {
    putcXLCD(c);
//Function to Initialise the LCD module
void init_XLCD(void)                //Initialize LCD display
    OpenXLCD(FOUR_BIT & LINES_5X7);  //configure LCD in 4-bit Data Interface mode
                                     //and 5x7 characters, multiple line display
    while(BusyXLCD());             //Check if the LCD controller is not busy
                                     //before writing some commands?
    WriteCmdXLCD(0x06);            // move cursor right, don?t shift display
    WriteCmdXLCD(0x0C);            //turn display on without cursor
/*  Main Application         */
void main(void) {
    unsigned char dht11_crc = 0;
    ADCON1 |= 0x0F; // ADC All Digital
    CMCON = 0x07; // Comparators off
    //Let the LCD Module start up
   Wait(1);
   //Initialize the LCD Module
   init_XLCD();
   Wait(8); // Some Delay
    dht_init(); // DHT11 PreInit
    /*Main Loop*/
    while (1) {
        memset(dht_dat, 0x0, sizeof (dht_dat));
        read_dht(); // Check dht_dat variable after this funciton
        dht11_crc = dht_dat[0] + dht_dat[1] + dht_dat[2] + dht_dat[3]; // check check_sum
        if (dht_dat[4] != dht11_crc || GlobalErr>0) {
            sprintf(t,"CRC ERR :%02x!%02X   ", dht_dat[4], dht11_crc);
            sprintf(n,"Resp. Err:%d   ", GlobalErr);
            putrsXLCD(t);         //Display humidity on the screen
            while(BusyXLCD());
            WriteCmdXLCD(0xC0);
            while(BusyXLCD());
            putsXLCD(n);           //Display the Temperature on the screen
        } else {
            sprintf(Buffer,"HUMI RH :%d.%d %%  ", dht_dat[0], dht_dat[1]);
             sprintf(Buffer1,"TEMP    :%d.%d %cC  ", dht_dat[2], dht_dat[3], 223);
            putrsXLCD(Buffer);         //Display "Voltage" on the screen
            while(BusyXLCD());
            WriteCmdXLCD(0xC0);
            while(BusyXLCD());
            putsXLCD(Buffer1);              //Display the Temperature on the screen
            putrsXLCD("   ");           // Clear after comma
            WriteCmdXLCD(0x02);
        Delay10KTCYx(250);
        Delay10KTCYx(250); // Min. 1sn
        //Delay10KTCYx(250);
        //Delay10KTCYx(250); // 2sn Ideal Delay
    } /* Main Loop Ends */
/* Main Applicaiton Ends */
void DelayFor18TCY(void){
    Delay10TCYx(20);
void DelayPORXLCD(void){
    Delay1KTCYx(30);
void DelayXLCD(void){
    Delay1KTCYx(10);
RE: Alexan_e
Reason: added SYNTAX tags
  /*Main Loop*/
    while (1) {
            while(BusyXLCD());
            WriteCmdXLCD(0xC0);
            while(BusyXLCD());
        } else {
            while(BusyXLCD());
            WriteCmdXLCD(0xC0);
            while(BusyXLCD());
            WriteCmdXLCD(0x02);
The part you highlighted was to convert the humidity and the temperature value to a string the dispay the to the lcd. I'm just a begginer in MCU programming, assist me the simpliest way possible
