interfacing 12bit ADC in SPI mode?
Sajjadkhan
Full Member level 5
Rawalpindi,Pakistan
hi, i ordered a 12bit ADC MCP3204 which has an SPI interface. Any good tutorial for SPI interface would be helpful.
One more thing MCP3204 will output 12 bit of serial data but PIC16f887 revieves only 8 bit, how to handle that?
hello
you have to use an integer ( 16 bits = 2 bytes !) variable to store the result.
see example in mikroC
it's not the same device , but the approach is similar..
test on MCP3304 4x 13bits ADC
value on 12 bits unsigned in single end mode.
ex: 0 à 5V for 0 ..4095 value
if your reference is 4.096V. you get directly input=4095 mv measure =4095 points
if you use differential mode:
value on 13 bits 1 for sign , 12 for value .
Why not reference the appnotes of the manufacture:
Microchip AN719 Interfacing Microchip’s MCP3201 Analog-to-Digital Converter to the PICmicro® Microcontroller
Microchip AN703 Using the MCP320X 12-Bit Serial A/D Converter with Microchip PICmicro® Devices
The above appnotes contain sample code in both C and Assembly.
Processing and storing a 12-bit ADC value is scarcely different the dealing with the 10-bit ADC value of the built-in ADC of PIC16F887.
The value will require two bytes of storage and either right or left justification.
BigDog
