interface the AT89C52 to the serial EEPROM AT24C04
eng_ahmed22
Full Member level 3
Full Member level 3
at24c04 code
Hi All,
I want to interface the AT89C52 to the serial EEPROM AT24C04. i did not make that be4.
could anybody send the scematic and the program to read & write to the EEPROM???
could u help?? hope so
thanks alot
bye :D
Ahmed
at24c04 application circuit
ATMEL website has application notes to do that. It might be for a different part number of chips. Just remember that the controller 89C2051 is software compatible with 89C52 and 24C04 is software compatible with all the 24C series memories.
24c08+8052+8052.com
Bus Master said:
Hi Ahmad,
What is your programming language? C, Assembly?
Hi Bus Master
thanks alot for ur help :D
i use c, keil c51
salam
Ahmed
eeprom 24c04 interfacing to 8052 for c code
Hi
I would definitely help you to achieve communication between AT89C52 and AT24C04 but have you created your code yet?
Please do not hestiate to PM me if you need help. I will try my best to help you
Maverick Max
eeprom at89s52
See this link good lib for 8052
SOKRAT
