Nov 24, 2009 #1 B brunofunchas Full Member level 3 Joined Jul 1, 2009 Messages 171 Helped 10 Reputation 20 Reaction score 7 Trophy points 1,298 Location Portugal Activity points 2,366 Hi! I have a simple Project where I just want to know when a circuit breaker trips. This CB does not have auxiliary contacts. So I thought that I can you use an interface and measure the voltage at the input of a PIC. To isolate the high side(240Vac) from the 5Vdc from the PIC I should use a relay to signal at the port of the PIC the presences or not of tension. Is it possible to do it with opto-couplers? Or another type of IC? Thanks, Bruno
Nov 24, 2009 #2 N nashwan Member level 5 Joined Jul 31, 2008 Messages 91 Helped 12 Reputation 24 Reaction score 0 Trophy points 1,286 Activity points 1,706 hi yes u can use ac solid state input moudel to interface high side 240v ac to ur pic **broken link removed**
Nov 25, 2009 #3 R rajtech Member level 2 Joined Dec 25, 2007 Messages 45 Helped 4 Reputation 8 Reaction score 2 Trophy points 1,288 Activity points 1,569 you can use a current transformer.
Nov 25, 2009 #4 nandhu015 Advanced Member level 5 Joined Feb 11, 2006 Messages 1,960 Helped 300 Reputation 600 Reaction score 222 Trophy points 1,353 Location India Activity points 9,924 There are isolated ADC's available in the market Google for it you will find a lot Nandhu Added : i found this one
Nov 25, 2009 #5 N nashwan Member level 5 Joined Jul 31, 2008 Messages 91 Helped 12 Reputation 24 Reaction score 0 Trophy points 1,286 Activity points 1,706 hi u can use this circuit to do interface between 240vac and 5vdc of a pic
Nov 25, 2009 #6 B brunofunchas Full Member level 3 Joined Jul 1, 2009 Messages 171 Helped 10 Reputation 20 Reaction score 7 Trophy points 1,298 Location Portugal Activity points 2,366 Hello! Thanks for all of the replies. It solved my problem. Best regards, Bruno
