Interface 32 ohm, 0.25W speaker with AT89C52
shigha
Junior Member level 1
I want to play music with AT89C52. I got the codes and simulated on proteus well. But i know that to get it in hardware, i must amplify it.
How can I do it?
Can I use LM386?
I used it but iam not getting any output. What should I do?
I used this ones circuit
Use these circuits. You need a filter between MCU o/p pin and op-amp input pin. You can't give digital o/p directly to op-amp input. You will get cracking noise.
But Iam not getting any sounds at all. Please note that Iam talking about 32 ohm speaker
