[SOLVED] integrating 2 programs
amit251291
Member level 1
Member level 1
hello,
In my project there are 2 parts 1) digital speedometer 2) speed monitoring (about which i told above)
I have prepared program of "digital speedometer" and "program to send a message". now I want to prepare a program which will send a message when speed is increased above particular limit. So how i should integrate this 2 programs to get final program?
Digital speedometer program:
$MOD51
LCD    EQU      P1    ;   P1.0 .....P1.7, PORT1 USED AS DATA BUS
RS     EQU      P3.2
RW     EQU      P3.3
EN     EQU      P3.7
DISTO  EQU      P3.4   ; TIMER 0 INPUT FOR DISTANCE-ODOMETER
SPEDO  EQU      P3.5   ; TIMER 1 INPUT FOR SPEEDOMETER
SCL   EQU        P3.0         ;SCL=PIN6
SDA   EQU        P3.1         ;SDA=PIN5
EEPROMW   EQU    10100000B     ; SLAVE ADDRESS  OF EEPROM 1010 000  + 0 TO WRITE
EEPROMR   EQU    10100001B     ; SLAVE ADDRESS  OF EEPROM  1010 000 + 1 TO READ
DSEG
ORG 020H                      ; BIT-ADDRESSABLE RAM
FLAGS:	  DS	  1           ; VARIABLES FOR I2C PROTOCOL
LASTREAD  BIT    FLAGS.0
SQW 	  BIT    FLAGS.4
ACK       BIT    FLAGS.5
BUS_FLT   BIT    FLAGS.6
_2W_BUSY  BIT    FLAGS.7
OK        BIT      1
BITCNT:	  DS		1
BYTECNT:  DS		1
POINT:  DS 1    ; DISTANCE VARIABLES
KM:     DS 1
TKM:   DS 1
HKM:   DS 1
KKM:   DS 1
TKKM:  DS 1
TOTAL: DS 1
STORE BIT  TOTAL.0
VAL1: DS 1   ; SPEED VAL1
VAL2: DS 1   ; SPEED VAL2
VAL3: DS 1   ; SPEED VAL3
SCL_HIGH  MACRO
          SETB   SCL      ; SET SCL HIGH
          JNB    SCL,$    ; LOOP UNTIL STRONG 1 ON SCL
          ENDM
CONVERT MACRO
   ORL A,#30H         ; CONVERT TO ASCII BY ADDING 30H
   ENDM
CSEG                              ; CODE BEGINS HERE
              ORG 0000H           ; ON RESET
              SJMP MAIN
              ORG 000BH	          ;Timer Interrupt0
              LJMP UPDATE
MAIN:  MOV SP,#70H       ; MOVE STACK POINTER TO ADDRESS 70H OF RAM
       LCALL PWR_DELAY   ;LCD POWER ON DELAY
       LCALL INIT        ;INITIALIZE LCD
       CLR STORE         ;CLEAR STORE FLAG
       MOV POINT,#00H    ; RESET ALL COUNTERS TO ZERO
       MOV KM,#00H
       MOV TKM,#00H
       MOV HKM,#00H
       MOV KKM,#00H
       MOV TKKM,#00H
       MOV VAL1,#00H     ; RESET SPEED VALUES TO ZERO
       MOV VAL2,#00H
       MOV VAL3,#00H
       LCALL READEEPROM   ; GET PREVIOUS READING FROM EEPROM
       LCALL SEND2LCD     ; DISPLAY INITIAL/PREVIOUS VALUES
       MOV TMOD,#66H    ; BOTH THE TIMERS SET AS COUNTERS IN MODE 2 - 8 BIT AUTO RELOAD
       MOV TH0,#203D    ; LOAD DISTANCE COUNTER TO COUNT 53 REVOLUTIONS(255-53+1)i,e 100 METERS
       MOV TL0,#203D
       SETB DISTO      ; T0 INPUT
       SETB SPEDO      ; T1 INPUT
       SETB ET0        ; ENABLE TR0 INTERRUPT
       SETB EA         ; GLOBAL ENABLE INTERRUPTS
       SETB TR0        ; START TIMER0
LOOP:  MOV TL1,#00H   ;  RESET SPEED COUNTER TO 00
       SETB TR1
       LCALL ONESEC_DELAY
       MOV B,TL1      ; COPY TL1 VALUE TO REGISTER B AFTER ONE SEC DELAY
       CLR TR1        ; STOP TR1
       MOV A,B
       JNZ GET_FIRST  ; CHECK IF SPEED IS ZERO
       SETB STORE     ; IF YES, SET STORE CURRENT READING FLAG
GET_FIRST: MOV DPTR,#FIRST        ; LOAD TABLE FOR FIRST DIGIT OF SPEED
           MOV A,B
           MOVC A,@A+DPTR
           MOV VAL1,A
GET_SECOND: MOV DPTR,#SECOND      ; LOAD TABLE FOR SECOND DIGIT OF SPEED
            MOV A,B
            MOVC A,@A+DPTR
            MOV VAL2,A
GET_THIRD: MOV DPTR,#THIRD        ; LOAD TABLE FOR THIRD DIGIT OF SPEED
           MOV A,B
           MOVC A,@A+DPTR
           MOV VAL3,A
           LCALL SEND2LCD          ; SEND VALUES TO LCD
           JBC STORE,STORE_DAT     ; CHECK IF STORE FLAG IS SET AND CLEAR THE FLAG
           SJMP LOOP               ; CONTINUE DOING THIS
STORE_DAT: LCALL SEND2EEPROM       ; IF SPEED IS = 00.0 THEN SAVE THE MILEAGE IN EEPROM
           SJMP LOOP
;             TIMER 0 ISR  - TO MEASURE DISTANCE
UPDATE:  INC POINT
         MOV R0,POINT
         CJNE R0,#10D,EXIT
         MOV POINT,#00H
         INC KM
         MOV R0,KM
         CJNE R0,#10D,EXIT
         MOV KM,#00H
         INC TKM
         MOV R0,TKM
         CJNE R0,#10D,EXIT
         MOV TKM,#00H
         INC HKM
         MOV R0,HKM
         CJNE R0,#10D,EXIT
         MOV HKM,#00H
         INC KKM
         MOV R0,KKM
         CJNE R0,#10D,EXIT
         INC TKKM
         MOV R0,TKKM
         CJNE R0,#10D,EXIT
         MOV POINT,#00H       ; WHEN 99,999 Kms, RESET ALL COUNTERS TO ZERO
         MOV KM,#00H
         MOV TKM,#00H
         MOV HKM,#00H
         MOV KKM,#00H
         MOV TKKM,#00H
 EXIT: RETI
ONESEC_DELAY:
     	MOV R0,#10D    ; One second delay routine
RZ3: 	MOV R1,#100D
RZ1:	MOV R2,#250D
RZ2:	NOP
	NOP
	DJNZ R2,RZ2
	DJNZ R1,RZ1
	DJNZ R0,RZ3
        RET
SEND2LCD:
       MOV A,#84H     ; LINE 1
       LCALL CMD
       MOV A,TKKM
       CONVERT
       LCALL DAT
       MOV A,KKM
       CONVERT
       LCALL DAT
       MOV A,HKM
       CONVERT
       LCALL DAT
       MOV A,TKM
       CONVERT
       LCALL DAT
       MOV A,KM
       CONVERT
       LCALL DAT
       MOV A,#'.'
       LCALL DAT
       MOV A,POINT
       CONVERT
       LCALL DAT
       MOV A,#0CBH    ; LINE 2
       LCALL CMD
       MOV A,VAL1
       CONVERT
       LCALL DAT
       MOV A,VAL2
       CONVERT
       LCALL DAT
       MOV A,#'.'
       LCALL DAT
       MOV A,VAL3
       CONVERT
       LCALL DAT
       RET
  READY:SETB EN ;H->L PULSE ON E
        CLR  RS ;RS=0 CMD
        SETB RW ;RW=1 FOR READ
        SETB P1.7 ;D7 AS INPUT
        JB P1.7,READY
        CLR EN
        CLR RW
        RET
   DAT:   SETB EN ;H->L PULSE ON E
          SETB RS ;RS=1 DATA
          CLR RW ;RW=0 FOR WRITE
          MOV LCD,A ;MOVE ACC.DATA TO PORT
          CLR EN
          NOP
          LCALL READY
          RET
   CMD:      SETB EN ;H->L PULSE ON E
             CLR RS  ;RS=0 FOR COMMAND
             MOV LCD,A ;MOVE ACC. DATA TO PORT
             CLR EN
             NOP
             LCALL READY
             RET
INIT:           MOV A,#030H   ;INITIALIZE LCD BY SENDING 30H THREE TIMES.
                LCALL  CMD
                ACALL DDELAY  ;INITIAL DELAY 4.1MSEC
                MOV A,#030H
                LCALL  CMD
                ACALL DDELAY
                MOV A,#030H
                LCALL  CMD
                ACALL DDELAY
                MOV A,#038H   ; INITIALIZE, 2-LINES, 5X7 MATRIX.
                LCALL  CMD
                ACALL DDELAY
                MOV A,#0CH    ;  INVISIBLE CURSOR ON;
                LCALL  CMD
                MOV A,#01H    ; CLEAR LCD SCREEN
                LCALL  CMD
                MOV A,#06H    ; SHIFT CURSOR RIGHT
                LCALL  CMD
                MOV A,#80H       ; LINE 1
                LCALL CMD
                MOV DPTR,#MSG_1
        LINE1:  CLR A
                MOVC A,@A+DPTR
                JZ NEXTLINE
                ACALL DAT
                INC DPTR
                SJMP LINE1
      NEXTLINE: MOV A,#0C0H       ; LINE 2
                LCALL CMD
                MOV DPTR,#MSG_2
        LINE11: CLR A
                MOVC A,@A+DPTR
                JZ DONE
                ACALL DAT
                INC DPTR
                SJMP LINE11
         DONE:  RET
CLEAR:  MOV A,#01H
        LCALL  CMD
        RET
DDELAY:  MOV R5,#41D           ; 4.1 mS DELAY
    QT2: MOV R6,#50D
    QT1: DJNZ R6,QT1
         DJNZ R5,QT2
         RET
;                I2C - SERIAL EEPROM ROUTINES
; THIS SUB READS ONE BYTE OF DATA FROM THE EEPROM
READ_BYTE:
         MOV         BITCNT,#08H; SET COUNTER FOR 8-BITS DATA
         MOV         A,#00H
         SETB        SDA        ; SET SDA HIGH TO ENSURE LINE
                                ; FREE
READ_BITS:
         SCL_HIGH               ; TRANSITION SCL LOW-TO-HIGH
         MOV         C,SDA      ; MOVE DATA BIT INTO CARRY
         RLC         A          ; ROTATE CARRY-BIT INTO ACC.0
         CLR         SCL        ; TRANSITION SCL HIGH-TO-LOW
         DJNZ        BITCNT,READ_BITS
                                ; LOOP FOR 8-BITS
         JB          LASTREAD,ACKN
                                ; CHECK TO SEE IF THIS IS
                                ; THE LAST READ
         CLR         SDA        ; IF NOT LAST READ SEND ACK-BIT
ACKN:
         SCL_HIGH               ; PULSE SCL TO TRANSMIT ACKNOWLEDGE
         CLR         SCL        ; OR NOT ACKNOWLEDGE BIT
         RET
;         SUB SENDS START CONDITION
SEND_START:
         SETB        _2W_BUSY   ; INDICATE THAT 2-WIRE
         CLR         ACK        ; OPERATION IS IN PROGRESS
         CLR         BUS_FLT    ; CLEAR STATUS FLAGS
         JNB         SCL,FAULT
         JNB         SDA,FAULT
         SETB        SDA        ; BEGIN START CODITION
         SCL_HIGH
         CLR         SDA
         ACALL       DEELAY
         CLR         SCL
         RET
FAULT:
         SETB        BUS_FLT
         RET
;          SUB SENDS STOP CONDITION
SEND_STOP:
         CLR         SDA
         SCL_HIGH
         SETB        SDA
         CLR         _2W_BUSY
         RET
; SUB DELAYS THE BUS
DEELAY:
         NOP                    ; DELAY FOR BUS TIMING
         RET
; THIS SUB SENDS 1 BYTE OF DATA TO THE EEPROM
SEND_BYTE:
SB_LOOP:
         JNB         ACC.7,NOTONE ; CHECK TO SEE IF BIT-7 OF
         SETB        SDA          ; ACC IS A 1, AND SET SDA HIGH
         JMP         ONE
NOTONE:
         CLR         SDA             ; CLR SDA LOW
ONE:
         RL          A               ; ROTATE ACC LEFT 1-BIT
         CLR         SCL             ; TRANSITION SCL LOW-TO-HIGH
         DJNZ        BITCNT,SB_LOOP  ; LOOP FOR 8-BITS
         SETB        SDA        ; SET SDA HIGH TO LOOK FOR
         SCL_HIGH               ; ACKNOWLEDGE PULSE
         CLR         ACK
         JNB         SDA,SB_EX  ; CHECK FOR ACK OR NOT ACK
         SETB        ACK        ; SET ACKNOWLEDGE FLAG FOR
                                ; NOT ACK
SB_EX:
         ACALL       DEELAY      ; DELAY FOR AN OPERATION
         RET
;  SUB READS FROM THE EEPROM AND WRITES IT TO THE SCRATCHPAD MEMORY
READEEPROM:
         MOV         R1,#POINT      ;  START FROM POINT STORAGE LOCATION
         MOV         BYTECNT,#00H
         CLR         LASTREAD
         LCALL       SEND_START
         MOV         A,#EEPROMW
         LCALL       SEND_BYTE
         MOV         A,#00H         ; POINT TO 00H ADDRESS OF EEPROM
         LCALL       SEND_BYTE
         LCALL       SEND_STOP
         LCALL       SEND_START
         MOV        A,#EEPROMR      ; READ COMMAND
         LCALL       SEND_BYTE
READ_LOOP:
         MOV         A,BYTECNT
         CJNE        A,#06H,NOT_LAST  ;  CHECK FOR THE LAST BYTE
         SETB        LASTREAD
NOT_LAST:
         LCALL       READ_BYTE
         MOV         @R1,A
         MOV         A,BYTECNT
         CJNE        A,#00H,NOT_FIRST
         MOV         A,@R1
         MOV         @R1,A
NOT_FIRST:
         INC         R1              ;** INC RAM LOCATION **
         INC         BYTECNT
         MOV         A,BYTECNT
         CJNE        A,#07H,READ_LOOP  ; CHECK FOR 7th BYTE,IF 7th BYTE THEN STOP TRANSFER
         LCALL       SEND_STOP
         RET
SEND2EEPROM:
	LCALL SEND_START 		; SEND 2WIRE START CONDITION
	MOV A,#EEPROMW 			; LOAD EEPROM WRITE COMMAND
	LCALL SEND_BYTE 		; SEND WRITE COMMAND
	MOV A,#00H                      ; SET EEPROM DATA POINTER TO 00H (ADDRESS LOCATION)
	LCALL SEND_BYTE
	MOV A,POINT                     ; Send POINT
	LCALL SEND_BYTE
	MOV A,KM			; Send KM
	LCALL SEND_BYTE
	MOV A,TKM			; Send TKM
	LCALL SEND_BYTE
	MOV A,HKM			; Send HKM
	LCALL SEND_BYTE
	MOV A,KKM 	                ; Send KKM
	LCALL SEND_BYTE
	MOV A,TKKM			; Send TKM
	LCALL SEND_BYTE
	LCALL SEND_STOP 		; SEND 2WIRE STOP CONDITION
	RET
PWR_DELAY:                       ; 15 mSec DELAY FOR LCD TO INTIALIZE AFTER POWER-ON
          MOV R4,#30D
H2:       MOV R3,#250D
H1:       DJNZ R3,H1
          DJNZ R4,H2
          RET
 ORG 0350H
MSG_1: DB 'Kms:',00H
MSG_2: DB 'Speed-Kmph:',00H
FIRST:
DB 0H,0H,1H,2H,2H,3H,4H,4H,5H,6H,6H,7H,8H,8H,9H,0H
SECOND:
DB 0H,6H,3H,0H,7H,4H,0H,7H,4H,1H,8H,4H,1H,8H,5H,0H
THIRD:
DB 0H,8H,6H,4H,2H,0H,8H,6H,4H,2H,0H,8H,6H,4H,2H,0H
END
Program to send messages on a mobile number:
ORG 0000H
		MOV TMOD,#20H	   		//TIMER 1, MODE 2
		MOV TH1,#-3				//9600 BAUD RATE
		MOV SCON,#50H			//8 BIT, 1 STOP, EN ENABLED
		SETB TR1
		acall delay
		acall delay
		acall delay
		acall delay
		MOV DPTR,#MSG1
		ACALL H1
		ACALL DELAY
		MOV DPTR,#MSG2
		ACALL H1
		ACALL DELAY
		MOV DPTR,#MSG4
		ACALL H1
		ACALL DELAY
		MOV DPTR,#MSG5
		ACALL H1
		ACALL DELAY
viay: sjmp viay
H1:  	CLR A
		MOVC A,@A+DPTR
		JZ B1
		ACALL SEND
		INC DPTR
		SJMP H1
B1:
		RET
SEND: 	MOV SBUF,A
H2: 	JNB TI,H2
		CLR TI
		RET
DELAY:  mov R5,#10H
HERE1: MOV R3,#0ffH
HERE2:  MOV R4,#0ffH
HERE:	DJNZ R4,HERE
		DJNZ R3,HERE2
		DJNZ R5,HERE1
		RET
ORG 300H
MSG1: DB "AT",0DH
	  DB 0H
MSG2: DB "AT+CMGF=1",0DH
	  DB 0H
MSG4: DB "AT+CMGS=",'"1234567888"',0DH
	  DB 0H
MSG5: DB "TEXT",0X1A
	  DB 0H
	  END
i have prepared this program by integrating above these 2 programs. But problem with this is (if all logic is correct) it will send a message when speed is greater than 6 km/hr but less than 10 km/hr as only 1 bit is monitored.. please go through these program and guide me correction/modifications required.
Controller: AT89C51
Its okay if it shows nothing on lcd when controller is executing a message routine.
waiting for reply,
$MOD51
RS     EQU      P3.2
RW     EQU      P3.3
EN     EQU      P3.7
SCL   EQU        P2.0         ;SCL=PIN6
SDA   EQU        P2.1         ;SDA=PIN5
DSEG
SQW 	  BIT    FLAGS.4
ACK       BIT    FLAGS.5
BUS_FLT   BIT    FLAGS.6
OK        BIT      1
BITCNT:	  DS		1
BYTECNT:  DS		1
KM:     DS 1
TKM:   DS 1
HKM:   DS 1
KKM:   DS 1
TKKM:  DS 1
TOTAL: DS 1
STORE BIT  TOTAL.0
SCL_HIGH  MACRO
          ENDM
CONVERT MACRO
   ENDM
              SJMP MAIN
              LJMP UPDATE
       MOV KM,#00H
       MOV TKM,#00H
       MOV HKM,#00H
       MOV KKM,#00H
       MOV TKKM,#00H
       MOV VAL2,#00H
       MOV VAL3,#00H
       MOV TL0,#203D
       SETB TR1
       LCALL ONESEC_DELAY
       CLR TR1        ; STOP TR1
       MOV A,B
           MOV A,B
           MOVC A,@A+DPTR
           MOV VAL1,A
            MOV A,B
            MOVC A,@A+DPTR
            MOV VAL2,A
			CJNE A,#06H,GREATER
			LJMP GET_THIRD
GREATER:   JNC SEND_SMS
		   LJMP GET_THIRD
SEND_SMS:
		SETB TR1
		ACALL DELAY1
		MOV DPTR,#MSG1
		ACALL S1
		ACALL DELAY1
		MOV DPTR,#MSG2
		ACALL S1
		ACALL DELAY1
		MOV DPTR,#MSG4
		ACALL S1
		ACALL DELAY1
		MOV DPTR,#MSG5
		ACALL S1
		ACALL DELAY1
        LJMP MAIN
S1:  	CLR A
		MOVC A,@A+DPTR
		JZ B1
		ACALL SEND
		INC DPTR
		SJMP S1
B1:
		RET
SEND: 	MOV SBUF,A
S2: 	JNB TI,S2
		CLR TI
		RET
DELAY1:  mov R5,#02H
HERE1: MOV R3,#0ffH
HERE2:  MOV R4,#0ffH
HERE:	DJNZ R4,HERE
		DJNZ R3,HERE2
		DJNZ R5,HERE1
		RET
           MOV A,B
           MOVC A,@A+DPTR
           MOV VAL3,A
           LJMP LOOP               ; CONTINUE DOING THIS
           LJMP LOOP
UPDATE:  INC POINT
         MOV R0,POINT
         CJNE R0,#10D,EXIT
         MOV POINT,#00H
         INC KM
         MOV R0,KM
         CJNE R0,#10D,EXIT
         MOV KM,#00H
         INC TKM
         MOV R0,TKM
         CJNE R0,#10D,EXIT
         MOV TKM,#00H
         INC HKM
         MOV R0,HKM
         CJNE R0,#10D,EXIT
         MOV HKM,#00H
         INC KKM
         MOV R0,KKM
         CJNE R0,#10D,EXIT
         INC TKKM
         MOV R0,TKKM
         CJNE R0,#10D,EXIT
         MOV KM,#00H
         MOV TKM,#00H
         MOV HKM,#00H
         MOV KKM,#00H
         MOV TKKM,#00H
 EXIT: RETI
ONESEC_DELAY:
RZ3: 	MOV R1,#100D
RZ1:	MOV R2,#250D
RZ2:	NOP
	NOP
	DJNZ R2,RZ2
	DJNZ R1,RZ1
	DJNZ R0,RZ3
        RET
SEND2LCD:
       MOV A,#84H     ; LINE 1
       LCALL CMD
       MOV A,TKKM
       CONVERT
       LCALL DAT
       MOV A,KKM
       CONVERT
       LCALL DAT
       MOV A,HKM
       CONVERT
       LCALL DAT
       MOV A,TKM
       CONVERT
       LCALL DAT
       MOV A,KM
       CONVERT
       LCALL DAT
       MOV A,#'.'
       LCALL DAT
       MOV A,POINT
       CONVERT
       LCALL DAT
       LCALL CMD
       MOV A,VAL1
       CONVERT
       LCALL DAT
       MOV A,VAL2
       CONVERT
       LCALL DAT
       MOV A,#'.'
       LCALL DAT
       MOV A,VAL3
       CONVERT
       LCALL DAT
       RET
        CLR  RS ;RS=0 CMD
        JB P1.7,READY
        CLR EN
        CLR RW
        RET
          SETB RS ;RS=1 DATA
          CLR EN
          NOP
          LCALL READY
          RET
             CLR EN
             NOP
             LCALL READY
             RET
                LCALL  CMD
                MOV A,#030H
                LCALL  CMD
                ACALL DDELAY
                MOV A,#030H
                LCALL  CMD
                ACALL DDELAY
                LCALL  CMD
                ACALL DDELAY
                LCALL  CMD
                LCALL  CMD
                LCALL  CMD
                MOV A,#80H       ; LINE 1
                LCALL CMD
                MOV DPTR,#MSG_1
        LINE1:  CLR A
                MOVC A,@A+DPTR
                JZ NEXTLINE
                ACALL DAT
                INC DPTR
                SJMP LINE1
                LCALL CMD
                MOV DPTR,#MSG_2
        LINE11: CLR A
                MOVC A,@A+DPTR
                JZ DONE
                ACALL DAT
                INC DPTR
                SJMP LINE11
         DONE:  RET
CLEAR:  MOV A,#01H
        LCALL  CMD
        RET
    QT2: MOV R6,#50D
    QT1: DJNZ R6,QT1
         DJNZ R5,QT2
         RET
READ_BYTE:
         MOV         A,#00H
                                ; FREE
READ_BITS:
                                ; LOOP FOR 8-BITS
         JB          LASTREAD,ACKN
                                ; THE LAST READ
ACKN:
         RET
SEND_START:
         JNB         SCL,FAULT
         JNB         SDA,FAULT
         SCL_HIGH
         CLR         SDA
         ACALL       DEELAY
         CLR         SCL
         RET
FAULT:
         SETB        BUS_FLT
         RET
SEND_STOP:
         CLR         SDA
         SCL_HIGH
         SETB        SDA
         CLR         _2W_BUSY
         RET
DEELAY:
         RET
SEND_BYTE:
SB_LOOP:
         JMP         ONE
NOTONE:
ONE:
         CLR         ACK
                                ; NOT ACK
SB_EX:
         RET
READEEPROM:
         MOV         BYTECNT,#00H
         CLR         LASTREAD
         LCALL       SEND_START
         MOV         A,#EEPROMW
         LCALL       SEND_BYTE
         LCALL       SEND_BYTE
         LCALL       SEND_STOP
         LCALL       SEND_START
         LCALL       SEND_BYTE
READ_LOOP:
         MOV         A,BYTECNT
         SETB        LASTREAD
NOT_LAST:
         LCALL       READ_BYTE
         MOV         @R1,A
         MOV         A,BYTECNT
         MOV         A,@R1
         MOV         @R1,A
NOT_FIRST:
         INC         BYTECNT
         MOV         A,BYTECNT
         LCALL       SEND_STOP
         RET
SEND2EEPROM:
	LCALL SEND_BYTE
	LCALL SEND_BYTE
	MOV A,KM			; Send KM
	LCALL SEND_BYTE
	LCALL SEND_BYTE
	LCALL SEND_BYTE
	LCALL SEND_BYTE
	LCALL SEND_BYTE
	RET
          MOV R4,#30D
H2:       MOV R3,#250D
H1:       DJNZ R3,H1
          DJNZ R4,H2
          RET
ORG 300H
MSG1: DB "AT",0DH
	  DB 0H
	  DB 0H
	  DB 0H
	  DB 0H
 ORG 0350H
FIRST:
SECOND:
THIRD:
END
Use a piece of paper and write pseudo code of your concept. Then use finite state machines to integrate your design.
