[SOLVED] Integer to string convertor for mikroC
shubham kumar
Member level 3
bangalore
Hi
I am using MikroC and PIC18F452.
I am trying to make integer to string function by myself but the output is not correct.
When I am running the same code in debug mode.. the values in there are correct but when I display it on LCD they are different.
// LCD module connections
sbit LCD_RS at LATD6_bit;
sbit LCD_EN at LATD7_bit;
sbit LCD_D4 at LATB4_bit;
sbit LCD_D5 at LATB5_bit;
sbit LCD_D6 at LATB6_bit;
sbit LCD_D7 at LATB7_bit;
sbit LCD_RS_Direction at TRISD6_bit;
sbit LCD_EN_Direction at TRISD7_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
// End LCD module connections
#include <stdio.h>
#include<stdio.h>
#include<string.h>
#include<math.h>
int displ(int, char *);
int main()
char arr[16];
int i=-398;
  LCD_init();
  Lcd_Cmd(_LCD_CLEAR);
displ(i,arr);
/*for(i=0;arr[i]!='\0';i++)
printf("%d",arr[i]) ;*/
 LCD_out(1,1,arr);
return 0;
int displ( int i,char *n)
char test_arr[16];
char j=0,l;
int sign,k=0,p=0;   // k,p are looping variables
if(i<0)
sign=i;
i=-i;
while(i>0)                     // this will store the integer digits in reverse
n[j++]= i%10;
i=i/10;
if(sign<0)                                // till here total number will be reversed
n[j++]=  '-';
n[j]= '\0';
for(p=0,k=j-1;k>=0;p++,k--)               // above number is again reversed and stored using pointer
                                                     // address
test_arr[p]=  n[k];
for(k=0;test_arr[k]!='\0';k++)                     // converting a integer to its character value
{                                                           // 48 in character refers to 0
test_arr[k]=test_arr[k]+48;
n[k]=  test_arr[k];
  if((sign<0) && (k==0))  {                        // if number is negative then make it to '-' sign
  test_arr[0]=test_arr[0]-48;
  n[0]=  test_arr[0];
n[k] = '\0';            // not necessary -- if want to check till n[k]!='\0'
/*for(k=0;k<j;k++)
    printf("%d",test_arr[k]);
 LCD_out(2,1,test_arr);
 return 0;
The values of variables in the debug mode are perfectly fine. but not working when trying to display on LCD
Are you terminating the test_arr with a null character before sending it to LCD_Out() ?
Yup, I am terminating it with null character
#include <stdio.h>
#include<stdio.h>
#include<string.h>
#include<math.h>
void LC_cmd(unsigned char);
void LC_out(unsigned char ,unsigned char ,  char *);
void LC_dat(unsigned char);
void LC_ini(void);
int main()
char arr[16];
int i=-43;
  LCD_init();
displ(i,arr);
 LCD_out(1,1,arr);
return 0;
char test_arr[16];
char j=0,l;
int sign,k=0,p=0,t;
if(i<0)
sign=i;
i=-i;
while(i>0)
t= i%10;
t=t+48;
n[j++] = (char) t;
i=i/10;
if(sign<0)
n[j++]=  '-';
n[j]= '\0';
test_arr[p]=  n[k];
 test_arr[p]='\0';
test_arr[k]=test_arr[k];
n[k]=  test_arr[k];
/*if((sign<0) && (k==0))  {
  n[0]=  test_arr[0];
n[k] = '\0';
 return 0;
I reached till here.
Here everything is working good apart from the thing that it is showing minus (-) sign before positive and negative numbers.
When I check the array values in debug mode there is no problem (I mean it is showing correct values.
I found the mistake. Thanks.
for variable sign, I didn't initialize it with 0, therefore it was taking previous value and giving - sign.
Thanks a lot. :)
@ milan.rajik
Hi.
My Integer to string program is working efficiently and LCD out program is working perfectly and independently.
When I tries to combine both , then it is not working.
While running, in one program, for "inttostr" I used inbuilt function for LCD,
in another program, for LCD I used inbuilt integer to string function.
Now I combined both my programs, it is not giving correct result.
Where can be the problem...
sorry I forgot to post the code
#define WAIT {LCD_EN=1; Delay_us(100); LCD_EN =0; Delay_us(100);}
void LC_ini(void);
void main(){
int i=5,p=-19138 ;
char ldg[]="MIkrOC",j,txt[16],txt1[16];
    TRISD=0X00;
    PORTD=0X00;
    TRISB=0X00;
    PORTD=0X00;
    LC_ini();
        Displ(p,txt1);
        LC_out(1,1,txt1);
        LC_out(2,8,"miKRoc");
void LC_ini(void){
     LC_cmd(0x33);    // Reset LCD
     LC_cmd(0x32);
     LC_cmd(0X28);    // 4 bit mode
     LC_cmd(0X0E);    // display on sursor blinking
     LC_cmd(0X01);    // clear LCd
     LC_cmd(0X80);    // row1 initial position 6
void LC_cmd(unsigned char k){
    PORTB= (k & 0xF0);      // sending higher nibble
    LCD_RS=0;          // command
    WAIT
    PORTB= ((k & 0x0F)<<4);    //sending lower nibble
    WAIT
void LC_dat(unsigned char k){
    LCD_RS=1;
    WAIT
    PORTB= ((k & 0x0F)<<4);       // sending lower nibble
    LCD_RS=1;
    WAIT
  void LC_out(unsigned char row,unsigned char col, char *str )
    switch(row) {
         case 1: LC_cmd(0x80 + col-1); break;
         case 2: LC_cmd(0xC0 + col-1); break;
         default: LC_cmd(0x80 + col-1);break;
     while(*str)
       LC_dat(*str++);
char test_arr[16];
char j=0,l;
int sign=0,k=0,p=0,ttt=0;
if(i<0)
sign=i;
i=-i;
while(i>0)
ttt= i%10;
ttt=ttt+48;
n[j++] = (char) ttt;
i=i/10;
if(sign<0)
n[j++]=  '-';
n[j]= '\0';
test_arr[p]=  n[k];
 test_arr[p]='\0';
n[k]=  test_arr[k];
n[k] = '\0';
 LC_out(2,1,test_arr);
 return 0;
