Installing Cadence in Linux Mint [question]
april1975
Member level 2
Hi
Is it possible to install Cadence Ic5141 on Linux Mint? Has anyone experince about it?
I have installed cadence 6 on ubuntu! but I assume the procedure should be the same!
hello sgharagoz
can you explain the procedure ? i have seen another post about installing on linux, but the procedure failed for mint.
Sorry I almost forgot to reply!
I can send you the procedure! send me your email!
By the way If your cadence has NCSU libraries then we may have a problem installing it, Since mine doesn't have.
https://www.eda.ncsu.edu/wiki/NCSU_EDA_Wiki
Cheers
Hi there,
Did you get my message? Was it helpful?
Cheers
Reactions: russian_girl
    V
    russian_girl
