sebo
Newbie level 3
Hello All,
I know this question has already been **broken link removed**. However, I am not sure it really solved the issue. Here is the message:
"Must" proposed to install some libraries for backward compatibility issues. Did anyone try it?
I tried to set the LD_ASSUME_KERNEL variable. Unsuccessful. But i think I need to use it only when installation process has been completed.
"tlihu" told us he installed Cadence on RH9.0 after modifying and recompiling some C files:
What are the modifications? Any suggestions?
thanks for your help and time!
Seb
tar: This does not look like a tar archive
tar: Skipping to next header
tar: Archive contains obsolescent base-64 headers
tar: Error exit delayed from previous errors
/home/vg/c/install/bin.lnx86/softload: line 1412:
Could not extract information from FS.0 of CD#1.
Could not get platform or release information: command not found
I have successfully installed Cadence IC5032 on RH9 and it runs pretty well so far.
However, during installation, I had to modify and recompile (gcc) some programs under install/bin.lnx86 (something like that). After that, the installation proceeded smoothly.
Two programs must be modified and then recompiled: io_filt.c and cdsudp.c.
Seb
