Insertion loss refers to any device INSERTED between source and load. If you insert a cable with IL=10 dB, so you will see10 db less at the load. If you add another device, cable or "platform", the load gets less power by the IL(s). If you cascade the lossy devices, you sum up their insertion losses.
