Inrush limitation for X2 capacitors in Offline PFC'd SMPS?
T
treez
The attached is a FET based inrush limiter for a Boost PFC’s output capacitance.
Is it worth having an inrush resistor for the X2 caps aswell (as shown). For example, for a 250W, 240VAC Boost PFC, a 1R,3W inrush resistor could be used just upstream of the X2 caps.
Or is this not worth it?
The X2 capacitor datasheets don’t allure to inrush protection measures
https://www.illinoiscapacitor.com/pdf/seriesDocuments/MKP series.pdf
  • Inrush into Boost PFC.pdf
Only an inrush limiter resistor for Bulk capacitance is enough. The product we have designed in the past up-to (2 to 3 kW) ,we have never faced any issue for X-cap Inrush. However ,you must provide a bleeder resistor to discharge it once disconnected
