archunan_m
Newbie level 3
An ideal op-amp is usually can be summarized by the two "golden rules":
I. The output attempts to do whatever is necessary to make the voltage difference between the inputs zero.
II. The inputs draw no current.
Input impedance, (Zin) Infinite - Input impedance is the ratio of input voltage to input current and is assumed to be infinite to prevent any current flowing from the source supply into the amplifiers input circuitry (Iin =0). Real op-amps have input leakage currents from a few pico-amps to a few milli-amps.
Is the input impedance of an op-amp (consider it is connected in negative config) with all ideal components, being infinity is practically possible???
