Input Impedance of an inductor in ADS with S parameters
An_RF_Newbie
Member level 3
here is my simple project:
I calculated the inductance value to have J50 reactance at 500Mhz. As you see the output results, S-parameters and input impedance, the real part and image part of input impedance are not correct. As you see the input impedance should have imaginary part but it shows me just real part. I changed the parallel resistor value to 1000Mega Ohm, but the imaginary part just became zero.
what is my mistake?
Solution
If you look at Zin, you see the inductor in series with the port 2 impedance.
Try a single port simulation using a regular Term port with 2 nodes (not TermG) and connect the inductor to these two nodes.
--- Updated ---
I forgot to mention that your de-activated WIRE uses the "deactivate and short" function, so it shorts the inductor. Only the port 2 resistance remains.
--- Updated ---
Solution
LaTeX Commands Quick-Menu:
