Input Capacitor calculations
Bjtpower
Full Member level 5
Dear Friends
I am verifying the One PCB.
PCB Specifications are
Input Voltage:110VAC=155.54V (Max)
Output Power: 100W
Line frequency=50HZ
now they have used the 100uF/450V capacitor of Rubycon.
When i was calculating
Power=voltage x Load current
Load Current=Power/Voltage=100/155.54=0.64A
now, Capacitor Required=I(load)/2xFXRipple=0.64/(2X50X15.55)=0.64/(1555)=0.64/10=411uF
Pls Help me Where i am getting wrong because my cap value is 4 times bigger.
Marx
Welll here is ltspice simulation which shows your dc bus variation with 100uf
but yes, generally, most cheaper electrolytics of 100uf would get over ripple currented by being attached as a dc bus cap in a non pfc smps of 100w power level. But maybe your load is not on max all the time?
  • Constant power load _100W.TXT
