In most applications which use any popular Op-Amp IC, the currents In and Ip will be very small currents. These are input currents and the designer might not even bother to calculate any terms which include these currents. They would probably use a low or zero value for Rp and maybe a low value for R1 so that these currents become insignificant.
To answer your question, the term R2*In is introducing a small voltage at the output (Vo) which will be a result of the small current flowing into the inverting input, In.
R2*In will be a very small positive value.
Have you built this circuit? Have you been able to measure any voltage at the output, Vo?
because that is one of the few things that Op-Amps are designed to do!.. how can it produce voltage with feedback resistor???
