inout ports in verilog
kaelk
Newbie level 2
Newbie level 2
Dear all;
I have the following error with modelsim
Error: module_uart/biDirBuffer.sv(6): An inout port (dat_io) must be a net type.
ad the code for the moule is below
Code Verilog - [expand]
8
9
10
module biDirBuffer(
   input  logic       outEn,
   input  logic [7:0] dat_i,
   output logic [7:0] dat_o,
   inout  logic  [7:0] dat_io
   assign dat_o = dat_io;
   assign dat_io = outEn ? dat_i : 'Z;
endmodule
I think that I made he correct assignments, if you have any idea please help
Thanks
Try "inout wire [7:0] dat_io" or just plain "inout [7:0] dat_io" instead. Because, well, an inout port (dat_io) must be a net type. The error message says it all really.
Reactions: kaelk
    kaelk
thanks mrflibble, I tried it and it works,
yes I understand that the error message says that inout data_io must be a net/wire
but I thin that a logic type can get a Z value ? no?
Thanks
