buenos
Advanced Member level 3
- Joined
- Oct 24, 2005
- Messages
- 956
- Helped
- 40
- Reputation
- 82
- Reaction score
- 21
- Trophy points
- 1,298
- Location
- Sunnyvale, California, USA
- Activity points
- 9,071
com port init sequence
hi
could someone tell me the setup sequence of the PC com1 port? and also send a byte out. some simple c code without lots of constant names used but with direct raw hex numbers in the code.
what i need is address+data, address+data, address+data... setup sequence to make the UART core functional.
i have an FPGA project and I want to simualte the 16550 uart if it is working or not wihin my code. for the simulation, i will have to generate a signal assertion sequence (stimulus) as bus transactions and observe the TX pin in the simulator.
hi
