gui lenh lcd 4 bit
Here is init routine for LCD 4-bit and Using PIC. Compiler is CCS
// lcd_lib_4bit.c
#include <stddef.h>
#define LCD_RS PIN_D2
//#define LCD_RW PIN_A1
#define LCD_EN PIN_D3
#define LCD_D4 PIN_D4
#define LCD_D5 PIN_D5
#define LCD_D6 PIN_D6
#define LCD_D7 PIN_D7
// misc display defines-
#define Line_1 0x80
#define Line_2 0xC0
#define Clear_Scr 0x01
// prototype statements
#separate void LCD_Init ( void );// ham khoi tao LCD
#separate void LCD_SetPosition ( unsigned int cX );//Thiet lap vi tri con tro
#separate void LCD_PutChar ( unsigned int cX );// Ham viet1kitu/1chuoi len LCD
#separate void LCD_PutCmd ( unsigned int cX) ;// Ham gui lenh len LCD
#separate void LCD_PulseEnable ( void );// Xung kich hoat
#separate void LCD_SetData ( unsigned int cX );// Dat du lieu len chan Data
// D/n Cong
#use standard_io ( B )
#use standard_io (A)
//khoi tao LCD**********************************************
LCD_SetData ( 0x00 );
delay_ms(200);
output_low ( LCD_RS ); // Command mode
LCD_SetData ( 0x03 ); //
LCD_PulseEnable();
LCD_PulseEnable();
LCD_PulseEnable();
LCD_SetData ( 0x02 );
LCD_PulseEnable();
LCD_PutCmd ( 0x2C );
LCD_PutCmd ( 0b00001100);
LCD_PutCmd ( 0x06 );
LCD_PutCmd ( 0x01 );
/* this subroutine works specifically for 4-bit Port A */
LCD_SetData ( swap ( cX ) | 0x08 );
LCD_PulseEnable();
LCD_SetData ( swap ( cX ) );
LCD_PulseEnable();
output_high ( LCD_RS );
LCD_PutCmd( cX );
#separate void LCD_PutCmd ( unsigned int cX )
LCD_SetData ( swap ( cX ) ); /* send high nibble */
LCD_PulseEnable();
LCD_SetData ( swap ( cX ) ); /* send low nibble */
LCD_PulseEnable();
output_high ( LCD_EN );
delay_us ( 3 ); // was 10
output_low ( LCD_EN );
delay_ms ( 3 ); // was 5
output_bit ( LCD_D4, cX & 0x01 );
output_bit ( LCD_D5, cX & 0x02 );
output_bit ( LCD_D6, cX & 0x04 );
output_bit ( LCD_D7, cX & 0x08 );
Gft from vietnam
www.dientuvietnam.net
Added after 5 minutes:
For AT89 and AVR is the same routine
