liuyonggen_1
Full Member level 4
Could you tell me the kinds of constant current control about parallel LED?
Thanks for your help!
elantra said:Normally parallel LEDs are drived by charge pump circuit, and the driver seems like paralleled LDOs. Use resistor to sample the current to keep the current constant. sometimes it is diffuricult to keep the leds the same brightness. current match of 0.006 is quite a commerical value. Some companies such as linear tech provide such products, you can search and have a look.
