praki
Newbie level 5
hello all , built a full bridge inverter using p-channel mosfet ( irf9540) for high side and n-channel mosfet(irf540) for low side . triggered the mosfets using ir2110 . the output measured by the multimeter is 12V . but on connecting the stepup transformer the output voltage drops to oV suggesting a short circuit . but the transformer works perfect as a step down trans. the same transformer when connected directly across the driver output terminals the measured input voltage is 5V and the output is 85V. battery = 12V , 5Ah , transformer 12-0-12, 1A.
will appreciate your response thank you
