Hamid.Kiumarsi
Full Member level 2
Hi
I have used two methods to get L and Q of an on-chip inductor in TSMC 0.18um.
1) Using the inductor in TSMC's ADS PDK (from palette in schematic view)
2) Using the exact same structure of the above pcell and simulating it with Momentum
at 1.8 GHz, L and Q got from above methods are:
1) L= 560 pH, Q= 9
2) L= 618 pH, Q= 15
I am quite handy using Momentum so I doubt that these discrepancies are results of my poor settings.
There is no problem in the defined substrate (measured and simulated S-parameters of other passive devices match with each other)
What could be the problem? don't you think that L and Q from ADS PDK should be accurate?
1) L= 560 pH, Q= 9
2) L= 618 pH, Q= 15
