R
red_alert
I'm looking for a method to individually protect (overcurrent) multiple parallel connected MOSFETs.
It's a H-bridge design and I want to use a separate fuse for every single MOSFET. The easiest method could have been putting the fuse on the drain circuit but I'm using a single non insulated aluminium heatsink for all parallel MOSFETs thus all drains are already shunted.
If I put the fuse in source circuit, I'm affraid that when the fuse will blow (to protect the MOSFET) the source terminal will float so the gate might catch a parasite overvoltage or something.
If I put the the gate-source resistor (1k) before the fuse, could I avoid this scenario?
Is there any other method to individually protect those MOSFETs?
