khan303
My fpga is spartan 3E-100 Cp132 (BASYS2). I have four push buttons as my inputs and I want to increment the four digits on 7-segment of the board by using them. The VHDL code is below:
Every pushbutton should increment the corresponding 7-segment digit (b1 --> rightmost digit and b4--> leftmost digit) by one. The problem is when I push the button, it does the job but not increment it by one but some arbitrary number. The reason is that it increments by one at every rising edge of the clock 2, which happens too quickly due to the frequency of this clock. How can I manage to get rid of this problem? I tried several debouncing code for the push buttons but they weren't helpful so much. I am totally stuck here. I mean there should be a way to do it, right? By the way, the debouncing code that I have been using with the code above is
Any help will be appreciated, thanks in advance!
entity main is
port(b1,b2,b3,b4 : in STD_LOGIC;
clk : in STD_LOGIC;
sseg : out STD_LOGIC_VECTOR(0 to 6);
anodes : out STD_LOGIC_VECTOR(3 downto 0);
reset : in STD_LOGIC
end main;
architecture Behavioral of main is
signal bcd1, bcd2, bcd3, bcd4 : STD_LOGIC_VECTOR (3 downto 0);
signal clk2 : STD_LOGIC;
signal pushbuttons : STD_LOGIC_VECTOR(3 downto 0);
signal db_pushbuttons : STD_LOGIC_VECTOR(3 downto 0);
signal counter : STD_LOGIC_VECTOR(1 downto 0);
signal clk_divider : STD_LOGIC_VECTOR(20 downto 0);
component Debounce is
port( cclk : in STD_LOGIC;
inp : in STD_LOGIC_VECTOR(3 downto 0);
cclr : in STD_LOGIC;
db : out STD_LOGIC_VECTOR(3 downto 0)
end component;
begin
pushbuttons <= b4 & b3 & b2 & b1;
Db : Debounce port map
( cclk => clk2,
inp => pushbuttons,
cclr => reset,
db => db_pushbuttons);
process (clk)
begin
if rising_edge(clk) then
if clk_divider <= "1100001101010000" then
clk_divider <= clk_divider + 1;
clk2 <= '0';
else
clk_divider <= (others => '0');
clk2 <= '1';
end if;
end if;
end process;
process (clk2, reset)
begin
if reset = '1' then
-- do something here
bcd1 <= "0000";
bcd2 <= "0000";
bcd3 <= "0000";
bcd4 <= "0000";
elsif rising_edge(clk2) then
counter <= counter + 1;
if db_pushbuttons(0) = '1' then -- db_b1
if bcd1 <= "1000" then
bcd1 <= bcd1 + 1;
else
bcd1 <= "0000";
end if;
elsif db_pushbuttons(1) = '1' then -- db_b2
if bcd2 <= "1000" then
bcd2 <= bcd2 + 1;
else
bcd2 <= "0000";
end if;
elsif db_pushbuttons(2) = '1' then -- db_b3
if bcd3 <= "1000" then
bcd3 <= bcd3 + 1;
else
bcd3 <= "0000";
end if;
elsif db_pushbuttons(3) = '1' then --db_b4
if bcd4 <= "1000" then
bcd4 <= bcd4 + 1;
else
bcd4 <= "0000";
end if;
end if;
end if;
end process;
process (counter, bcd1, bcd2, bcd3, bcd4)
variable display : STD_LOGIC_VECTOR(3 downto 0);
begin
case counter is
when "00" => anodes <= "1110"; display := bcd1;
when "01" => anodes <= "1101"; display := bcd2;
when "10" => anodes <= "1011"; display := bcd3;
when "11" => anodes <= "0111"; display := bcd4;
when others => null;
end case;
case display is
when "0000" => sseg <= "0000001"; --0
when "0001" => sseg <= "1001111"; --1
when "0010" => sseg <= "0010010"; --2
when "0011" => sseg <= "0000110"; --3
when "0100" => sseg <= "1001100"; --4
when "0101" => sseg <= "0100100"; --5
when "0110" => sseg <= "0100000"; --6
when "0111" => sseg <= "0001111"; --7
when "1000" => sseg <= "0000000"; --8
when "1001" => sseg <= "0000100"; --9
when others => sseg <= "0010000"; --e, represents error
end case;
end process;
end Behavioral;
entity Debounce is
port(cclk : in STD_LOGIC;
end Debounce;
architecture Behavioral of Debounce is
signal delay1, delay2, delay3 : STD_LOGIC_VECTOR(3 downto 0);
begin
process (cclk, cclr)
begin
if cclr = '1' then
delay1 <= "0000";
delay2 <= "0000";
delay3 <= "0000";
elsif rising_edge(cclk) then
delay1 <= inp;
delay2 <= delay1;
delay3 <= delay2;
end if;
end process;
db <= delay1 and delay2 and delay3;
end Behavioral;
