Increase the voltage at the output pin of optocoupler?
rhnrgn
Member level 5
Member level 5
Hello,
We are using your SFH6732 model Vishays optocoupler.
We applied 5V to its VCC and 24V 6.2ma to its input.
When i measure its output i see 3.8V. In order to make a PIC's input pin high, voltae should be at least 4V.
Can i do anything in order to get at least 4V from optocouplers output except increase Vcc. Can i use pull-ups?
Thank You.
Datasheet
https://www.vishay.com/docs/83685/sfh6731.pdf
Reference Designs
I would try pull-ups, e.g. 1k. If it doesn't work, use optocouplers with CMOS output specification or level converters.
Reactions: rhnrgn
    rhnrgn
