Incoming call based Motor ON/OFF
ragav4456
Full Member level 4
Full Member level 4
Hi
am using sim 300 for this project. here am doing incoming call based and number entering in keypad based motor on / off system.
How to receive after attend the call, pressed keypad values?
pressed Keypad value based motor On/off.
Eg- Press 8- Motor On, Press 9- Motor Off.
Emergengy, Reply quickly.
Thanks
You want to dial a number from Tx board to Rx board and if Rx board receives the call then you want to press some keys at Tx board and depending upon control the motor ON/OFF at Rx board ???
If yes, the Tx system has to send ATDxxxxxxxxxx; command to Rx board. The Tx system should wait till a response for call received is received. If true then keypad routine should be enabled. Now you enter key and the keyvalue is sent to Rx board. Rx board reads the keyvalue and depending upon the value turns ON/OFF the motor. At Tx board you should also provide a option to redial number say 3 times if the call was not received and take some other action after this.
You have to use AT+CLCC to get the status of dial. You might also need to implement code to reset GSM at both RX and Tx system if GSM responds to commands (say 3 attempts). Connect GSM reset pin to microcontroller for this purpose.
Do you also want to use keypad for dialing purpose?
AT+CLCC command is not working. i studied in gsm AT command datasheet, Mention List of current calls of me.
The command is for SIM900. I don't know command for SIM300. Read SIM300 AT Command manual. For SIM900 if you give
AT+CLCC
you get
AT+CLCC
+CLCC: 1,0,3,0,0,"99xxxxxxxx",129
OK
as response.
You can see 3 in the response. The position corresponding to 3 in response have different value during dialing, after dialing and if call is active.
https://www.activexperts.com/serial-port-component/tutorials/gsmdial/
Edit: If you want to control device from any modile then give the below command to receiver GSM modem.
AT+CLIP=1
//Send once
AT+CLIP=1
//response
OK
//Incoming call is notified as below
RING
+CLIP: "xxxxxxxxxxxx",145,"",0,"",0
RING
You have to do it only once. When ever the modem receives a call (Incoming call) you get
RING
You can read this using microcontroller.
Read post#8 and #9 here.
https://www.8051projects.net/t59453/embedded-gsm-development/i-want-few-at-commands-sim300-gsm.htm
