include library in a verilog file
dengelpolar
Newbie level 3
Newbie level 3
i met a 'unexpected' error while including a library in a verilog file.
****************verilog file*************
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
and when i compiled thie file , i met
Error: E:/ModelSim/Modelsim10/examples/taxi.v(6): near ";": syntax error, unexpected ';', expecting STRING_LITERAL
what is the problem?
thank you for any help~
aha, grate for your help.
is there any way to use the ieee libarary in Verilog? or i'd best found a new VHDL file to do my job?
u can save that vhdl coding for seprate file ____.vhd and call that entity to component of the ur verilog file; don't compile ur _____.v file inside of vhdl coding....
o yes, thank you very much!
Verilog has no libraries. The IEEE specs for 1164 are built into the verilog language (1,0, Z and X). Std_logic_unsigned is NOT an IEEE library.
