the pcb design has been coppered,now i want to modify some place.
but the copper pour become a hindrance for me to move some routing line.
I have a idea :first delete all the copper pour ,then modify the lines,
Could you give me a suggestion? Thanks
you could select copper pour or select modify copper pour and click on the copper pour. this will select the entire copper pour and you could delete or modify it.
In your case, no need to delete the copper pour. You just click on the preference option, inside there will be the option to choose whether you allow the tracks to be possible to drag through the polygon (I think your copper pour is the polygon, isn't it?).
