[SOLVED] In 8051 MC, Why must a logic 1 be written to the port pin to make it an input pin?
shantilal.s50
Junior Member level 1
Jaipur
I refers to the "The 8051 Microcontroller And Embedded Systems Using Assembly And C" by Muhammad Ali Mazidi in which it was mentioned that to use any port of 8051 as input port the logic 1 must be written to the port pins.why?
without this also u can sense input & keep in mind for input always required pull up resistor
Have a look at this:
Part way down it explains "Why must a logic 1 be written to the port pin to make it an input pin?"
Keith
Because when u assign 1 to any pin it get connect to Vcc and if u assign 0 then it connect it to Gnd.
when i/p pin get gnd then it complete its route so we read as 0 and vice versa.
