Improvement for laser tracking code outside dark room
sakurarandom
Junior Member level 3
I had try on laser tracking on my green laser with coding as shown below. It works if the laser dot in a dark room. Is there any suggestion on how to improve it? I would like to improve it to scan only for coordinate x from 100 to 260 while coordinate y from 300 to 360. Thanks.
close all%Ckise all figure windows except those created by imtool
%closepreview(vid);
%delete(vid);
clear; %Delete all variables
%close(gcf);
clc %Clear command window
clear
imtool close all %Make sure the workspsace panel in showing
vid=videoinput('winvideo',1,'RGB24_640X480');
vid.FramesPerTrigger = 1;
start(vid);
wait(vid);
preview(vid);
xResolution = 640;
yResolution = 480;
intensityThreshold = 250;
tic
while toc < 15
theSnapshot = getsnapshot(vid);
figure(1);
imshow(theSnapshot);
% reset the corner extremes
leftMost = xResolution;
rightMost = 0;
topMost = yResolution;
bottomMost = 0;
[x y] = size (theSnapshot);
for i = 1: xResolution
for j = 1:yResolution
if theSnapshot(i,j,2) > intensityThreshold
% bright green pixel found
if i < topMost
topMost = i;
end
if i > bottomMost
bottomMost = i;
end
if j < leftMost
leftMost = j;
end
if j > rightMost
rightMost = j;
end
end
end
end
% calculate the midpoints of the area
if leftMost ~= xResolution && rightMost ~= 0
% both leftMost and RightMost have been updated
laserFound = true;
laserX = (leftMost + rightMost)/2
laserY = (topMost + bottomMost)/2
else
% unable to find laser
laserFound = false;
end
% plot laser area
% for ease of viewing, y coordinates are viewed flipped around into
% the cartesian system instead of image coordinate system
if laserFound == true
figure(1);
impixelinfo
hold on;
plot((0: xResolution),laserY*ones(1, xResolution+1),'r');
plot(laserX*ones(1, yResolution+1),(0:yResolution),'r');
hold off;
axis([0 xResolution 0 yResolution]);
drawnow;
end
end
% Stop the acquisition, remove the object from memory,
% and clear the variable.
stop(vid)
delete(vid)
clear vid
try to improve sensitivity of detector for peak and slow decay behaviour so if scanning too fast, it will reduce chance of being missed.
Also use green color filter to block out stray wavelengths of light say from pulsing FL tubes.
