promach
Could anyone think of ways to further reduce the resource usage compared to the original coding approach ?
Reference:
Reference link from StackExchange
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity tiny_rs232_tx is Port ( clk : in STD_LOGIC; bit_tick : in STD_LOGIC; data : in STD_LOGIC_VECTOR(7 downto 0); data_enable : in STD_LOGIC; tx : out STD_LOGIC := '1'; busy : out STD_LOGIC ); end tiny_rs232_tx; architecture Behavioral of tiny_rs232_tx is signal shift_reg : std_logic_vector(9 downto 0) := (others => '1'); signal i_busy : std_logic; begin busy <= i_busy; with shift_reg select i_busy <= '0' when "0000000000", '1' when others; clk_proc: process(clk) begin if rising_edge(clk) then if i_busy = '0' and data_enable = '1' then shift_reg <= '1' & data & '0'; end if; if bit_tick = '1' then if i_busy = '1' then tx <= shift_reg(0); shift_reg <= '0' & shift_reg(9 downto 1); end if; end if; end if; end process; end Behavioral;
Reference:
